need help with turbo d16 build
Old Dec 20, 2012 | 05:04 AM
drew wade's Avatar
Default need help with turbo d16 build
ok guys ycp pistons,pins,and rings,with eagle rods, mini ram speed factory, t3/t4e,57 trim,stage 3 turbine wheel graaett journal bearing , speed factory 4 bar map sensor, walbro hp 255 fuel pump and stock head what you think of my setup man
Old Dec 20, 2012 | 05:09 AM
yungkhmer's Avatar
Default Re: need help with turbo d16 build
Sounds gggggggreat!
Old Dec 20, 2012 | 05:12 AM
drew wade's Avatar
does anyone know about how much power i will be making
Old Dec 20, 2012 | 05:16 AM
JuggerNaut-CTR's Avatar
You have left out alot of information for any of us to even guess numbers for you....but then again, why would we??? You should have a goal for how much power you want, then you show up to the tuner, state your goal(s) for the car, and see what happens.
Old Dec 20, 2012 | 05:19 AM
drew wade's Avatar
250 to 300 to the wheels i going to run 93 gas and 20 pounds of boost its going to be a dd
Old Dec 20, 2012 | 05:22 AM
So, you have a goal on power but already know what psi your going to run? Thats not how it works...tell the tuner the goal and you'll see what happens....that means the boost pressure could be anything upon tuning...8, 10, 12, 15, 20 for all you know
Old Dec 20, 2012 | 05:24 AM
drew wade's Avatar
oh ok man thanks anything you could think of to make setup better
Old Dec 20, 2012 | 05:27 AM
Lots of things...but thats dependant upon money.
Dont see in your list fuel injector size, charge piping size, dp/exhaust size & setup.....
Old Dec 20, 2012 | 05:29 AM
drew wade's Avatar
3 inch exhaust money is 5 grand injector rc 680cc
Old Dec 20, 2012 | 12:31 PM
grumblemarc's Avatar
The Grumpiest
1,000,000 horsepowers!!!!!
Um. The horsepower figures are the first thing you should plan for.
Old Dec 20, 2012 | 12:54 PM
mechanix619's Avatar
OP, with all regards to helping you, I think you need to back up a few steps. There is a lot of missing information and misunderstood concepts in your posts.
Step 1: Forced Induction FAQ's
Old Dec 20, 2012 | 01:20 PM
Post #11......
Old Dec 20, 2012 | 03:10 PM
Julio@Bisimoto's Avatar
From what I read about your setup and power goals of 250-300hp, it will be no problem with a good tune. If you want to increase effiency and produce your power goals at lower boost pressures, a good turbo camshaft like a Bisimoto Level 2.4 with springs and retainers will greatly help you out. We have seen improvements of as much as 80whp over the factory camshaft at 20psi! Hit me up and I will hook you up with a deal on one!
Old Dec 20, 2012 | 03:57 PM
The Bisi Lv 2.4 seems more like a track cam. Isn't it a tad excessive for 250-300HP? How is the idle and daily drivability?
OP, research and remember to keep it simple.
Old Dec 20, 2012 | 06:06 PM
MalcolmV8's Avatar
I have a very similar setup. D16Y8 hear as a daily driver. You've left out a lot of misc stuff that will nickel and dime you. My setup mostly
CP 9:1, eagle rods, arp head studs, stock cam and head with a fresh valve job. Stock intake and throttle body on mine.
go-autoworks SS mainfold, precision 5431 turbo, tail wastegate, hks bov
255 lph fuel pump, ID 1000 injectors (over kill capacity but I got them for the superior drive ability and stable street manners since this was a DD)
Hondata S300, boost gauge, wideband and a real temp gauge (minimum required to do tuning imho)
4bar map, boost controller
J&S Vampire anti-knock (automatically pulls timing at the slightest hint of detonation and saves ones motor). An absolute must for the self tuner such as myself in my opinion.
NGK 7BRE plugs gapped around 0.28 (any bigger and I get spark blow out)
Ebay intercooler and piping + oil feed line. Custom built oil return.
2.5" custom made down pipe I built myself to keep a/c as well as recirculating dump tube. Full 3" exhaust with cat, resonator and dynmax
muffler. Electric cutout for fun.
Extra outlet welded to valve cover for two vents to catch can.
Check valve to protect PCV system when in boost. This keeps a functional PCV system. (most on this site delete PCV but doesn't mean its right).
SPAL fan for cooling
Stage 1.5 comp clutch, tranny rebuilt with carbon fiber syncros and m-factory locker. Some better rims and tires for traction.
Still to come: water/meth injection as I'm around 15 PSI on 91 pump gas and had to pull a fair amount of timing due to detonation. I think I'm only running around 10 or 11 degrees timing at WOT around 6k rpms. Providing the timing relationship between the S300 and my distributor is all set correctly that's what the tune is saying it is anyways.
I have not been on the dyno, car is street tuned, but my butto meter says approx 250 whp based on how it pulls and does with cars I race. Come spring I'll get it on a dyno and get timing dialed in correctly and see what it really makes.
As for your goal of 20 PSI on 93 octane, I'd say a lot of timing will be pulled to make that happen. It's somewhat counter intuitive, you could just as easily lower boost a little and add timing for the same HP... and you'd have cooler IATs at lower boost. Keep us updated.
Old Dec 20, 2012 | 06:36 PM
A boost number is not a goal but the means to a goal.
Old Dec 21, 2012 | 09:34 PM
drew wade's Avatar
should i buy a greddy turbo kit for 125 dollars its the turbo turbo manifold and down pipe
Old Dec 22, 2012 | 11:33 PM
wantboost's Avatar
Who is Mr Robot?
That one on eBay?
It will work, if you want to run a t2 based internally wastegated tuebo
Old Dec 23, 2012 | 05:27 AM
blackeg's Avatar
lol yeah you will be running like 8 degrees total timing at 20 psi.
here is some good advice. work on the gearing in your transmission. the oem sohc vtec trans is pretty long similar to b series ls trans.
Old Dec 23, 2012 | 06:47 AM
KevinEF7's Avatar
Save a few hundred and pick up some vitara pistons instead if your goal is 300whp
Old Dec 23, 2012 | 07:55 AM
wantboost's Avatar
Who is Mr Robot?
^without custom length rods his compression will be like 7.5:1 which is wayyyyy too low
Old Dec 23, 2012 | 10:48 AM
drew wade's Avatar
no my friend got the greddy kit its turbo turbo manifold and down pipe the turbo is td04 little turbo i was thinking for now it would work with my motor on like 15 psi and then when i want 300 in the summer i could buy a bigger turbo i already have vitara pistons and rods arp head studs 255 fuel pump oem head gasket block is bored and everything ready to go and the greddy kit is real boy payed 2,000 dollars for it 3 years ago
Old Dec 23, 2012 | 11:25 AM
wantboost's Avatar
Who is Mr Robot?
It would work
But some advice....
Ditch the stock downpipe and elbow, its tiny and restrictive, causes boost spikes, etc.
Build a 3" downpipe from turbo outlet back... and port the turbo inlet and the manifold outlet, they always have overlap.. also port the wastegate flapper hole... this will give you better boost control and stabikization , especially when combined/done with the bigger downpipe
Still thinking about boost the wrong way.
If you want to make 250, or any number, it'll take "X" amount of boost to reach such goal.
Boost is not a goal but a means to a goal.
Old Dec 23, 2012 | 12:18 PM
wantboost's Avatar
Who is Mr Robot?
exactly
dont expect mind boggling numbers from the 15g.... you'll make maybe 225... I've seen a guy with the greddy 18g kit on a y8 make mid 300s
