Need some pointers/help on my b18b1 swap
I have a 1997 civic dx hatchback that had a d16y7 in it that i just changed over to a b18b1 and i have managed to drop it in with all the mounts everything is wired up (used the y7 harness) but now the thing will not crank over
-the car was an automatic before so i wired up the car to signal it is in park
-i check all of the grounds
-the timing is correct
- i have fuel pressure
-im using a chipped obd1 ls ecu with a jumper harness
I check a majority of the fuses and they all seem fine
btw the car cranks but doesn't turn over
Im confused at this point and any input/advice would be greatly appreciated!
Re: Need some pointers/help on my b18b1 swap
yah id check spark...then id check timing and make sure the rotor button is on number 1 while the cam gear is pointed up. id check you ecu fuse or backup fuse or whatever its called.
