Need help trying to find compressor maps
Old May 15, 2003 | 08:20 PM
.(Lazarus).'s Avatar
Default Need help trying to find compressor maps
I've been trying to find maps for the T25 from the 2G Eclipse and for the S13 SR20DET. I'm trying to get parts together for a ghetto-charger for the Miata, and trying to figure out which turbo to swipe from the shop
Old May 15, 2003 | 08:40 PM
*Boostwerks*'s Avatar
Default Re: Need help trying to find compressor maps (ATXhybrid)
Mitsubishi doesn't use compressor maps. as far as I know they don't exist.
I would go with the SR20 though. It's bigger, and is better suited for the Miata. Is the Miata a 1.6l or 1.8?
Before I finally decided I was going to build up my CRX, I pondered with the thought of selling it and buying a 1.8l Miata to do a full T3/TO4E setup on. Those motors are "Supra" in strength...
Old May 15, 2003 | 08:58 PM
Default Re: Need help trying to find compressor maps (Bryson)
The miata is a 1.8L, which makes things alot harder as the more common 1.6L parts are not compatible. The goal of the setup is only about 30-40 rwhp. It's being built to e an "Eaton killer" that can do everything te JRSC can do w/o costing $2800. I'm looking at ~5psi non-intercooled, so a big turbo is not really important. I'm more worried about the efficiency numbers due to the lack of i/c.
I was leaning towards the SR20 since I believe it runs lower boost stock than a 4G63 (at least the S13 ones anyway), so it would hopefully be more suited to the low pressure ratios I'll be seeing
R3X5150
Nov 29, 2018 09:54 AM
vtiperu
Nov 21, 2007 10:09 AM
discopotato03
Mar 23, 2006 09:11 PM
the4ork
Jun 15, 2005 06:34 AM
fsp31
Feb 24, 2003 10:37 AM
