need help from SOHC greddy users...
Old Mar 28, 2003 | 01:25 AM
Racerage1's Avatar
Default need help from SOHC greddy users...
im installing the sohc kit on my 99 ex and im having problems with my tee fitting on the block...ive already unplugged the oil sensor and when i try to screw in the tee(no matter how i screw it) the feed line outlet isnt facing towards the driver side to hook up with the SS line...is there any special way to put it in so that its tight and faces towards the drivers side??? im realy stuck and i need a lot of help...
Old Mar 28, 2003 | 01:49 AM
TurBoXBirD16's Avatar
Default Re: need help from SOHC greddy users... (Racerage1)
i don't quite remember which side it faces...
but it should face the driver's side...
try tighten it abit to let it face to the driver's side
good luck
http://www.turbocivic.net is a good help
Old Mar 28, 2003 | 11:10 AM
Racerage1's Avatar
Default Re: need help from SOHC greddy users... (TurBoXBirD16)
ive been reading through turbocivic.net since i started the install...but every time i tighten it the tee would point up...the only way it would face towards the right is if i dont tighten it all the way...and theres no way of routing the feed line if the tee was pointing up or to the left...thanks for your help though...anyone else??im really frustrated right now and i need help...thanks
Red_Greddy_Si
Sep 2, 2004 03:46 PM
Racerage1
Mar 25, 2003 09:22 PM
Overblown-Teg
Dec 4, 2002 10:08 AM
Pengo
Aug 1, 2002 04:35 PM
Pengo
Jun 14, 2002 07:08 PM
