Need help on retarding my timing ??????????
Old Apr 24, 2003 | 09:03 PM
blown_LS's Avatar
Default Need help on retarding my timing ??????????
Hi guys, I just put the turbo kit for my 95 Integra and I just wanted to ask you which is the cheapest way to retard timing. I am planing on running 9 psi. I got everything else (garett t3, fmic,bov,charge piping, uptated fuel system) and retarding igition is all I need. And also how much should I retard. Please no bs just technical answers.
Thanks,
Old Apr 24, 2003 | 09:33 PM
Spunkster's Avatar
Default Re: Need help on retarding my timing ?????????? (blown_LS)
you want cheap or safe?
Best way would be a Hondata or something that will allow you to properly tune fuel and timing as well as all other aspects.
If you want something relatively cheap, you can use a boost timing retard device such as a BTM or BTC.
I have my Jackson Racing BTC and will sell it to you for $150 if you want it. can retard as little as 1/10th degree per psi up to 2 degrees per psi. This was designed for the supercharged cars but works just as well on turbos, boost is boost.
Old Apr 25, 2003 | 07:00 AM
b16ahybrid's Avatar
Default Re: Need help on retarding my timing ?????????? (Spunkster)
I highly recomend a btm you can get a new one for about $175 or find a used one for cheap (i paid $65). A less desireable way is to retard your timing by turning your distributor. That will effect your cam timing, injector timing, ignition timing and power output.
Old Apr 26, 2003 | 07:17 AM
blown_LS's Avatar
Default Re: Need help on retarding my timing ?????????? (b16ahybrid)
ok, do you have any websites that sell btm's for that price.
turbo boost
Oct 19, 2007 01:57 PM
miro_gt
Sep 19, 2005 02:17 PM
xcountrirunr
Dec 1, 2004 08:57 AM
bmm89
Nov 21, 2004 08:17 PM
CRXLST
Oct 27, 2004 09:45 PM
