Need help with resistor pack for '99 Si
I'm getting ready to wire in the resistor pack to run my bigger injectors. The only thing is that on pre-99-00 Civics the injector wires to tap into are on the driverside shock tower. Now on my car I don't see the same wires/harness as I do on my friends 92-95. So I'm going to assume I need to go behind the motor to find the correct set of wires and start from there. Another question is once I find the yellow and black wires and test them, by OMH's what number am I looking for? I just need a quick how to if anyone knows, since the cars in the air now. TIA, Allen
Hey, I just did this on my car ('99 Si). I used the wires at the injectors. Cut the yellow/black wires, run the part closest to the firewall (this is gonna be difficult to explain) and use those - bundle them all at the resistor box - as the input (red) wire to the resistor box. You should be left with 4 injector wires that are still hanging off the actual injector clips. Take the output (black) wires and individually run wire from the resistor pack to the end that's still hanging there. That way, you don't have to find any kind of master power wire and you don't have anything left hanging. Hope that makes sense, EV.
i heart honda
Feb 14, 2009 03:46 PM
the.hamburglar
Jul 25, 2005 09:29 PM
Zeus
May 30, 2003 03:07 PM
