need help with my profec b dont know how to use it
Old Jun 10, 2003 | 06:30 PM
TURBO B's Avatar
Default need help with my profec b dont know how to use it
need help with my profec b dont know how to use it i turned all the ***** all the way to the left and its on 9 psi so what did i do wrong ok i hooked the vac line on the back of the boost controller to the out nipple on the box and the in nipple i have a hose going from there to the wastegate and i still cant turn the boost down im on 9 psi i was on 5 psi wastegate now i cant turn it down what could i have done wrong
Old Jun 10, 2003 | 07:07 PM
TURBO B's Avatar
bump
Old Jun 10, 2003 | 08:10 PM
TURBO B's Avatar
Default Re: (TURBO B)
bump
Old Jun 11, 2003 | 09:37 AM
TURBO B's Avatar
ttt
Old Jun 11, 2003 | 10:22 AM
PM-Performance's Avatar
do you still have the bottom port of the wg hookd to a vac line, and the top port to the profec?
Old Jun 11, 2003 | 10:29 AM
K20  EG's Avatar
Default Re: (itr206)
you need to have one of the vacuum ports on the solenoid box going to the waste gate ...and one to a direct vacuum source off the manifold
that is why it is not working
remember to run it low to start
Good luck
Old Jun 11, 2003 | 10:33 AM
TURBO B's Avatar
still need help a pic would really help
Old Jun 11, 2003 | 10:40 AM
ok the way you had the wg before , leave it the same way , now all you do is take that open bottom port and put the solenoids in line with that same vac source your bottom wg port is feeding to, as far as the controller box port that goes to a direct vac source too , ie fpr vac source.
Old Jun 11, 2003 | 10:42 AM
drLazy's Avatar
u need to buy a 2 plastic "T" fitting at autozone($0.50) cut the vac line from the profecB to the black box insert the "T" fitting in between them and w/ the third nipple exposed connect another vac line to any other vac line on the intake manifold using the other "T"
Old Jun 11, 2003 | 11:00 AM
TURBO B's Avatar
a pic would be nice
Old Jun 11, 2003 | 11:03 AM
dont have pics that would help . i have pics of my engine bay, but prob wont help
Old Jun 11, 2003 | 11:04 AM
drLazy's Avatar
sorry dude they wont let me instant message but i'll explain it more but i dont have a digi cam
Old Jun 11, 2003 | 11:07 AM
TURBO B's Avatar
can i have a pic of your engine bay
Old Jun 11, 2003 | 11:17 AM
drLazy's Avatar
Default Re: (drLazy)
ok basically ur wastegate needs pressure form the intake manifold to open and close no matter if u have a controller or not. the controller is just a valve that goes between the vac line from ur wastegate to the intake manifold that u had before u bought the controler. its like a closed loop: wastegate<black box<profecB<back to the intake manifold. but u have it hooked up in a open loop: wastgate<black box<profecB<???? this is where u need to T off to a vac line on the intake manifold, just go to autozone ask them for 2 plastic T fittings and it should all make sense to u, so basically u need to route a vac line from any intake mani source (w/ a T) to the vac line form profecB to black box (w/ the other T)
black box
I
I I
intake mani I------------------I
I vac line I
I
profecB
Old Jun 11, 2003 | 11:20 AM
drLazy's Avatar
C:\Documents and Settings\Administrator\My Documents\FOB_DC-T\PICT0203.JPG
its not gonna help you much but enjoy .
Old Jun 11, 2003 | 11:22 AM
drLazy's Avatar
did that pix link work if not tell me how to post pics cause im new to the whole forum deal
Old Jun 11, 2003 | 11:28 AM
TURBO B's Avatar
no it didnt work
Old Jun 11, 2003 | 11:34 AM
you have to have em hosted. cant pull from your local drive.
zach1288
Jul 8, 2010 02:39 PM
boostek9
Jun 9, 2010 06:52 PM
boostedel
Feb 22, 2003 02:37 PM
vtectuner99
Aug 12, 2002 12:53 AM
