boost controller for civic need help
Old Aug 11, 2002 | 10:20 PM
vtectuner99's Avatar
Default boost controller for civic need help
need some help hooking up my blitz boost controller to my civic i have an external wastegate now but i doint know how to run the vacuum lines for it if you can help it would be helpfull thx
Old Aug 11, 2002 | 10:24 PM
Kamin's Avatar
Default Re: boost controller for civic need help (vtectuner99)
http://www.blitz-na.com/Blitz_Installation_Manuals.htm
dont know if its in there
i dont have the money for blitz products.
[Modified by KAMiN, 11:24 PM 8/11/2002]
Old Aug 11, 2002 | 10:32 PM
HondaCutter's Avatar
Default Re: boost controller for civic need help (KAMiN)
I'm not sure if it's the same for all boost controllers but I'll go with how the profec B was. there should have been a box type thing that came with it. The box should have two little nipple type things for the vacuum lines. that box, if there is one, should go between the wastegate and the vacuum source. then the box should be able to be hooked up the part that goes into the car ( the boost controller ). On the profec b there was a nipple on the back of the part that goes in the car. you should have a T fitting to tap into the vacuum line ( i guess anywhere ) then run that into the car and put that on the nipple. This is the installation of a profec B, I assume most boost controllers are the same. I hope this has been helpful.
Old Aug 11, 2002 | 11:28 PM
Default Re: boost controller for civic need help (HondaCutter)
thx for the info but i am still lost i have two vacuum lines that of of that box but if i do what you just said the the controller does not work unlimited boost in the car just keeps on going no control i need to find a manual for the blitz boost#ssbc
Old Aug 11, 2002 | 11:43 PM
Kamin's Avatar
http://www.blitz-na.com/Blitz_SBC_SPEC_S.htm
please tell me its that one
if you bought the other one its for twin turbo.
Old Aug 12, 2002 | 12:53 AM
you don't have to use the vacuum lines that they give you. if that's what's you're saying. try going here http://www.greddy.com/technical and look at the instructions to the profec b, if that doesn't help IM me.
[Modified by HondaCutter, 4:04 AM 8/12/2002]
marcussmith26
May 15, 2006 06:06 AM
importboi22
May 20, 2004 04:43 AM
streetrage
Oct 14, 2003 10:52 PM
