NEED HELP - mechanical or ECU problem?
Old Oct 18, 2010 | 05:30 AM
scarvalho's Avatar
Default NEED HELP - mechanical or ECU problem?
good evening friends
this week I had a problem with my civic. I have a sleeved b16 turbo and the engine detonated. my mechanic says it was failure of the distributor but that night had a new ECU at S300.
what is certain is that the distributor works on other cars.
When The distribuitor fails, the engine can be detonated ?? or is the problem is the ECU map???
I need your help because my engine have only 2000 miles
thanks
sory my english
Old Oct 18, 2010 | 05:32 AM
scarvalho's Avatar
Default Re: NEED HELP - mechanical or ECU problem?
one more,
the cilinder detonated is the first and theard ( 1 and 3)
Old Oct 18, 2010 | 07:10 AM
scarvalho's Avatar
Old Oct 18, 2010 | 07:27 AM
ashb82's Avatar
"that night had a new ECU at S300"
did you install a new s300 tune
Old Oct 18, 2010 | 07:38 AM
scarvalho's Avatar
yes
with new ecu tune, i only make 10km and BUUUMMMM
Old Oct 18, 2010 | 11:39 AM
TheShodan's Avatar
Moderator
There really needs to be more background information before any reasonable opinion could be given. 1) Who socketed the ECU, 2) Age of distibutor 3) was the car completely "tuned" before this went or was it a basemap used? 4) who assembled the engine, 5) what are specs of the engine, and what was used....
This could be ANYTHING either mechinical or software/hardware related.
Old Oct 18, 2010 | 11:45 AM
TJChad's Avatar
My guess isnt your distributor but rather the "base map" or whatever was loaded onto your S300. If you were to far advanced on your timing that could have cause this, but like Shodan said ALOT more information is needed.
Old Oct 18, 2010 | 01:01 PM
inspector01's Avatar
If you changed ECUs and only made it 10kms, Im guessing that is the problem, especially since you make it sound like it wasn't actually tuned. That what you get for driving on a basemap.
Old Oct 18, 2010 | 01:30 PM
scarvalho's Avatar
thanks,
so, i give more details:
1) my ECU is a realy hondata S300, not socketed
2) my distribuitor have 13years
3) the engine was assembled and made the running of 1200km at 6000rpm, after this the basemap was placed
4)here in portugal
5)sleeved b16
84mm CP pistons 9.0:1cr
micropolish and balanced crank
eagle rods
polish ITR head
supertech valves springs
Blox B cames
edelbrock victor X
70mm TB
and i only make 1200km on streets
Old Oct 18, 2010 | 01:50 PM
2k.civic.si's Avatar
im gonna take a guess here and say....the ecu was not tuned.
Old Oct 19, 2010 | 07:15 AM
scarvalho's Avatar
yes my friend
Old Oct 19, 2010 | 08:00 AM
turbociv910's Avatar
yes, your **** outa luck
Old Oct 19, 2010 | 08:08 AM
scarvalho's Avatar
tomorow go change my setup, and put new pistons and head and valves.......
next week i try a prototype exaust manifold and a PTE 6262
Old Oct 19, 2010 | 08:46 AM
and then you are going to tune right away right??
Old Oct 19, 2010 | 08:48 AM
scarvalho's Avatar
YES YES YES
now i need a wideband
samrsx
Engine Management and Tuning
Dec 11, 2017 05:45 PM
Cyphear
Mar 30, 2009 05:56 PM
Mi4dc5
Feb 24, 2004 04:52 AM
89civichatchback
Jan 18, 2003 07:58 AM
