Need help on intercooler size
Old May 15, 2015 | 04:56 AM
20vsleeper's Avatar
Default Need help on intercooler size
Hi All,
Need some help on picking out an intercooler size.
I've been trying to search around and it seems very confusing. I've come down to one calculation based on HP and have come up with a general size, however the calculation does not include the setup (not sure if that matters). So here is the setup
Stock JDM B18C ITR
Ramhorn manifold
GT3076
10psi
2.5 piping
The core size I came up with was 9" x 22" x 3"
Would love to get some feedback on core size.
Thanks
Old May 15, 2015 | 07:25 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: Need help on intercooler size
The type of core will matter more than the size at this point. You need to figure out what you can afford to spend on a quality intercooler and then after knowing it's efficiency you can select a core. Most manufacturers rate their cores for you so choosing isn't very hard at all.
Why are you running that turbo at that low of a pressure? Do you have the parts already? What are your HP goals? Do you plan to grow? Many questions to consider answering. Most setups (within reason) you can't go too big on the intercooler but it is easy to go to small. Also, available airflow cooling the intercooler will have a big effect as well.
Old May 15, 2015 | 07:50 AM
20vsleeper's Avatar
Thanks for the feedback! I will look into different quality of coolers.
Reason for the setup (haven't bought the parts yet, except for motor) is I'm looking to use it for lapping purposes while leaving it as a stock motor. Looking for low to mid 300's, I do not plan to change anything in the future.
Old May 15, 2015 | 11:16 AM
DO IT ON ALL FOURS
In that case there are definitely better turbo options out there. First, what do you mean by lapping? Are you talking AutoX, Road Racing, etc?
Old May 15, 2015 | 01:29 PM
TheShodan's Avatar
Moderator
He's got a good turbo base to start from, but needs to stay within its efficiency range whenever possible. He'll realize that as he goes to different courses, he'll need to tune above his normal comfort level so that he can keep up.
In the meantime,
Intercooler types and sizes
Old May 15, 2015 | 08:33 PM
20vsleeper's Avatar
The car will be used for road racing.
Great feedback!
I would love to hear alternatives on turbo setups. I decided on the gt3076 due to the efficency based on 1.68 (compressor graphs), however please provide feedback.
Thanks for the link on the intercooler, great info
Old May 16, 2015 | 10:59 AM
TheShodan's Avatar
Moderator
Great feedback!
On tracks across Europe, you'll rarely, if ever hit 1.68bar on a B-series Honda in Road racing, unless you're going to the South course of "The Ring".
1.7-1.8 is maximum efficiency for that wheel, and even then, its just under 52lbs/min. Plenty for the turbine wheel to go with, but there are other derivatives you can convert that CHRA to , in order to have a bit more room work with it, in the midrange where you'll need it most.
killablaze
Nov 28, 2005 08:46 PM
95GSRTT
May 23, 2005 11:35 AM
Guerillah
Oct 24, 2004 08:02 AM
VtecInteg95
May 10, 2003 09:04 AM
97integraLST
Mar 8, 2002 09:14 AM
