Need help with intercooler piping
Old Oct 7, 2004 | 01:14 PM
95excoupe's Avatar
Default Need help with intercooler piping
I am going to use these pipes http://www.jcwhitney.com/autop...10101 but I need to know what the hell it means when it says ID OD I am pretty shure its input diameter and output diameter but why is everyone different like the only ones that are the same say swaged infront of it? Its a SOHC with a greddy kit and a 30" long johnnyracecar intercooler anyone set anything up like that before?
Old Oct 7, 2004 | 01:57 PM
RyanEJ8's Avatar
Default Re: Need help with intercooler piping (95excoupe)
I am also going to be using the JC Whitney aluminized piping. ID = inside diameter, OD = outside diameter.
Old Oct 7, 2004 | 05:42 PM
95excoupe's Avatar
Default Re: Need help with intercooler piping (RyanCivic2000)
Thanks ok that makes more sense so what pipes are you going to use I want to be original and think this up myself but I dont want to blow money on too much or mess up and get to little.
Old Oct 7, 2004 | 05:45 PM
RyanEJ8's Avatar
81ZX3031U 180 Degree Mandrel-Bent Aluminized Tubing, (A/B)=12", (C)=5", ID=2-3/8", OD=2-1/2" (You will need to order two of these)
81ZX2953P 90 Degree Mandrel-Bent Aluminized Tubing, (A/B)=10", (C)=5", ID=2-3/8", OD=2-1/2"
81ZX3035N 180 Degree Mandrel-Bent Aluminized Tubing, (A/B)=24", (C)=5", ID=2-3/8", OD=2-1/2" (This one I am using to make my charge piping, so if you already have that, you don't need this pipe)
StolenTeg's Avatar
Mosy people use the 2.5 Diameter pipe, I recommended welding bead on them pipe because mine keep blowing off while boosting and it suck big time...
Old Oct 7, 2004 | 08:08 PM
95excoupe's Avatar
Default Re: Need help with intercooler piping (StolenTeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StolenTeg &raquo;</TD></TR><TR><TD CLASS="quote">Mosy people use the 2.5 Diameter pipe, I recommended welding bead on them pipe because mine keep blowing off while boosting and it suck big time...</TD></TR></TABLE>
Yeah on a larger turbo but ~2.3" should be fine for mine, the turbo is like the size of my fist.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RyanCivic2000 &raquo;</TD></TR><TR><TD CLASS="quote">81ZX3031U 180 Degree Mandrel-Bent Aluminized Tubing, (A/B)=12", (C)=5", ID=2-3/8", OD=2-1/2" (You will need to order two of these)
81ZX3035N 180 Degree Mandrel-Bent Aluminized Tubing, (A/B)=24", (C)=5", ID=2-3/8", OD=2-1/2" (This one I am using to make my charge piping, so if you already have that, you don't need this pipe)</TD></TR></TABLE>
Thank you I will order those up right now. So since this is coated aluminum welding this with a mig is going to be impossible right?
Old Oct 7, 2004 | 08:43 PM
RyanEJ8's Avatar
Not impossible, but it would be much better to use a TIG.
Old Oct 10, 2004 | 09:52 PM
adseguy's Avatar
You need to take the aluminum coating off (sanding). Then it's basically just mild steel so you can use anything to weld it.
Gr8DC2R
Welding / Fabrication
Nov 11, 2007 06:45 PM
alacard
15
Mar 28, 2006 03:32 AM
forcedaccord95
May 13, 2005 08:19 PM
nate951
Feb 6, 2005 07:19 PM
Racerage1
Apr 16, 2003 10:26 PM
