Need help identifying compressor
Old Mar 3, 2003 | 06:46 PM
Pat's Avatar
Pat
Default Need help identifying compressor
I'm wondering how I can tell if I have a T04B or T04E compressor. I see the letter B stamped on the comp, does that mean I have a T04B? What measurements can i do to confirm? I ordered a T04E and I already got the wrong a/r (got 0.5 instead of 0.6) from Maxrev so I hope I at least got a T04E
Here is a pic:
Also is this hole for the water line to run thru (just checking that I have a water cooled center section)
TIA
Old Mar 3, 2003 | 06:48 PM
HXMan's Avatar
Default Re: Need help identifying compressor (Pat)
Good question...they sent me the wrong turbine housing, but I sent in the wrong one, and they sent me the right one.
Old Mar 3, 2003 | 06:58 PM
AVATAR's Avatar
Default Re: Need help identifying compressor (HXMan)
T04E has six compressor blades and not seven
Old Mar 3, 2003 | 07:18 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: Need help identifying compressor (AVATAR)
Its an E comperssor wheel.
art
Old Mar 3, 2003 | 08:51 PM
B18EG6's Avatar
........i did not know that
(where is hatchblack...hes a lebowski fan)
Pat's Avatar
Pat
Default Re: Need help identifying compressor (Arturbo)
thanks guys , glad to hear
Old Mar 3, 2003 | 09:55 PM
Flamenco-T's Avatar
you look to have an E wheels with a machined B housing...the 50 AR
Old Mar 3, 2003 | 10:13 PM
DIRep972's Avatar
Smarter than you
thats looks to be a rather small wheel? its definitly a to4b housing, but what wheel is it? we could figure it out if u measure it w/ a caliper.
Old Mar 3, 2003 | 11:01 PM
turbopimp's Avatar
Yes, that turbo has a watercooled bearing housing... and you are correct in identifying the coolant connections.
Old Mar 4, 2003 | 04:05 PM
Pat's Avatar
Pat
Default Re: Need help identifying compressor (turbopimp)
cool thanks.
As for the compressor, I can always switch out the housing later right? Maybe I should just run the T04B... They are efficient up 300+ hp according to Revhard ? I plan to run 6-10 psi and not looking for more than 250whp at all. As of now , the specs are:
T3 turbine - .48 ar stg 3 wheel
T04B comp - 0.5 ar, supposedly 57 trim but presumable smaller now?
I don't want to deal with Canada Customs again and I'm afraid if I send it back they'll make another mistake
Old Mar 4, 2003 | 04:09 PM
LsTurbo91's Avatar
thats a E compressor housing. I use to run a 50trim wheel in a 50 a/r comp housing.
Old Mar 4, 2003 | 04:30 PM
Pat's Avatar
Pat
Default Re: Need help identifying compressor (LsTurbo91)
hmm what measurements can I do with a ruler to check out the specs? I'm getting confused now
Old Mar 4, 2003 | 06:28 PM
mckenzie's Avatar
that ******* sucks..i wish you had a E too..in that way i would have one aswell..
check out my dirty turbo http://www.geocities.com/trdngo/turbo.html
Old Mar 5, 2003 | 12:48 AM
Pat's Avatar
Pat
Default Re: Need help identifying compressor (egMee)
Your compressor inlet looks larger than mine? I measured the ID of the compressor inlet, it was 2 5/8". Does that tell me anything at all?
Old Mar 5, 2003 | 09:05 AM
LsTurbo91's Avatar
look here... I don't think there is a b or E compressor housing. If this is the same as a garrett catalog.
http://www.turboneticsinc.com/catalog/comp_wheels.html
looks like you have a standard .50 a/r compressor housing.
Old Mar 5, 2003 | 09:43 AM
avividmemory's Avatar
nice info source on turbonetics
mike93eh2
Dec 29, 2008 09:21 AM
EK k kay
Mar 3, 2006 07:24 PM
XDEep
Mar 26, 2004 11:37 PM
Zero_son
Mar 5, 2003 08:12 AM
Stock@$$GSR
Apr 18, 2002 06:22 AM
