need help figuring turbo fitting size.
Old Jul 30, 2010 | 11:56 AM
092eg6's Avatar
Default need help figuring turbo fitting size.
the feed hole on my turbo seems kinda big, i have a npt fitting that i found in the garage and it seems to fit into the feed hole fine, im not sure what npt fitting it is but i took my micrometer and measure the thread part, it measured out to 0.510". is that a 1/8 , 1/2 , or 1/4 NPT ?? im looking for a oil restrictor that will fit onto the turbo feed hole and also fit onto my oil line.
Old Jul 30, 2010 | 03:05 PM
SpeedFactoryRacing's Avatar
Default Re: need help figuring turbo fitting size.
Do you know what turbo you have?
Old Jul 30, 2010 | 08:52 PM
092eg6's Avatar
garrett 57 trim .60 compressor/ .48 turbine
Old Jul 31, 2010 | 08:54 AM
If it is a 57 trim then the oil feed line inlet is an 1/8" NPT fitting, and I would run a -3AN line with no restrictor to start.
Old Jul 31, 2010 | 09:42 AM
092eg6's Avatar
the hole is actually bigger than 1/8 npt thread, i got one fitting from a air tool and it fits into the turbo feed hole perfect. i think its a 1/4 npt thread.
BigZeke5
Oct 16, 2008 06:20 AM
Del$olB16A3
May 31, 2005 04:16 PM
projectxspeed
Apr 19, 2005 03:45 AM
