need help with a few things
Old Feb 14, 2007 | 11:32 AM
dazcivic's Avatar
Default need help with a few things
my car has been standing for about 1 year and it will soon be back on the road with a new turbo conversion (was turboed before i took it off the road)
and i have a few questions
as i said the car has been standing for a year and the engine aint been started in that time will this cause any probs to the engine
i will be doing a service , compression check, new cam seals needed and cam belt at the same time
is there anything else i should do and what should the compression be
and any other pointers before i acctually start the car
Old Feb 14, 2007 | 11:36 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: need help with a few things (dazcivic)
unplug the dizzy or take out the efi fuse and crank it till the oil light goes out, then replace and light off.
Old Feb 14, 2007 | 11:44 AM
dazcivic's Avatar
so pull the fuse and then turn it over till the light goes off put the fuse back but what u mean light off?
Old Feb 14, 2007 | 11:49 AM
Mr. Badwrench
Default Re: (dazcivic)
oil pressure light, it is on when the engine isnt running. goes out when it starts. basically what i am saying is to build oil pressure in the engine before you start it. i do it with all my swaps.
Old Feb 14, 2007 | 11:56 AM
dazcivic's Avatar
ok cool
thanx
is that all i need to do
Old Feb 14, 2007 | 12:39 PM
almostboostedgsr's Avatar
Thats too confusing. Just do this. Take your spark plugs out. turn the key to the power postion. For 50 seconds. Then crank the car over. Then put the spark plugs back in. Then start the car.
It does the same thing as he said above. Just easier.
tacchan
25
Apr 5, 2010 06:37 AM
Prudz_lude
Oct 11, 2006 08:24 AM
red92EG
Sep 25, 2006 07:59 PM
Sohc Driver
Jul 9, 2003 11:38 AM
b16_madman
12
Apr 17, 2003 05:39 AM
