NEED HELP FAST!
Old Feb 10, 2006 | 11:26 PM
SOHCVTECx2's Avatar
Default NEED HELP FAST!
i recently installed a turbo kit on my stock b16, running 440 injectors, hondata p72, and pretty much everything else to get it running. It would start fine and drive okay, but all of a sudden when i swapped out my Type R Cams to GSR cams, the motor won't crank over. Compression test was at 30 on all cylinders. can someone help me troubleshoot this problem?
Old Feb 10, 2006 | 11:27 PM
SOHCVTECx2's Avatar
Default Re: NEED HELP FAST! (SOHCVTECx2)
people were telling me that my land rings would fry first on a stock motor but i'm not sure, i want to know other peoples imput.
Old Feb 11, 2006 | 12:18 AM
EnzoSpeed's Avatar
Don't worry about the ring lands. If you *just* installed the new cam and you can't get compression, then you goofed on the install.
Old Feb 11, 2006 | 06:23 AM
SOHCVTECx2's Avatar
so now how would i go about fixing the problem? take out the cams and redo it again? the reason why is because when i would crank the car usually the whole car would shake a little before starting, but now it just spins and spins and spins.
Old Feb 11, 2006 | 08:25 AM
Turbo-charged's Avatar
Default Re: (SOHCVTECx2)
sounds like you have the cams 180 out?
Old Feb 11, 2006 | 08:48 AM
EBP.EM1's Avatar
Default Re: (Turbo-charged)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo-charged &raquo;</TD></TR><TR><TD CLASS="quote">sounds like you have the cams 180 out?</TD></TR></TABLE>
ditto
Old Feb 11, 2006 | 09:11 AM
JDM97R's Avatar
Or you have to adjust the valve clearance
Old Feb 11, 2006 | 09:16 AM
YouCantCatchMe's Avatar
your cam timing is off. Redo it, and make sure you know where the timing marks are.
Old Feb 13, 2006 | 11:38 AM
SOHCVTECx2's Avatar
thanks a lot you guys. you guys were right about the timing for a fact. What i also found out i have some funky cams. The gears were up but the way how the lobes are they are just out of order. If you guys want i can post a pic and you guys can see a big difference
Old Feb 13, 2006 | 06:43 PM
ek82's Avatar
damn you have all this money to blow but you cant even get my chipped p28 THAT YOU OWE ME!! i think it been about three or four month now since you BORROWED it and SOLD it along with your car....damn dude you dont have to be sooo fawking shaddy fool "i'm your LIL BRO"!
Old Feb 14, 2006 | 10:27 PM
SOHC SOLDIER's Avatar
Default Re: (ek82)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek82 &raquo;</TD></TR><TR><TD CLASS="quote">damn you have all this money to blow but you cant even get my chipped p28 THAT YOU OWE ME!! i think it been about three or four month now since you BORROWED it and SOLD it along with your car....damn dude you dont have to be sooo fawking shaddy fool "i'm your LIL BRO"! </TD></TR></TABLE>
Damn thats fucked up, sounds like a scammer to me Its carma he ripped you off now he tried to install cames and messed up. Dont try to fake the funk homie, you just messed up on the install
Old Feb 14, 2006 | 11:14 PM
andysila's Avatar
F scammers if you ask me....
you guys put the word "Trust" to shame..
Old Feb 18, 2006 | 04:12 PM
SOHCVTECx2's Avatar
first of all there was no scamming alright. I don't do shady business, secondly is going and will be returned, so i would appreciate it if you guys don't assume that i am a scammer, because i'm not.
TNT
Aug 17, 2007 01:36 PM
crawlin
Jun 3, 2007 04:01 PM
JDMkidGSR
Aug 28, 2005 04:04 PM
Fuzion
Apr 3, 2005 01:14 PM
