NEED HELP WITH DECISION: GSR or LS Block???
Old May 12, 2005 | 08:37 AM
Da K00l Aid Mayun's Avatar
Default NEED HELP WITH DECISION: GSR or LS Block???
Ok, to make a long story short. I have a GSR swapped in my 93 H
goals are 450hp on pump gas, and 600+ on race gas:
Setup:
Full-Race Manifold
Full-Race T4/T67 turbo
3" downpipe and exhaust
Tial 40mm Wastegate
RC Saturated 750cc injectors
Wiseco 81.5mm pistons
Eagle Rods
Type R crank
stock GSR head w/ port & polish
Here is my dilemma:
I am sleeving the block as we speak. My choices are either keep the GSR bottom end and sleeve it with AEBS sleeves or to buy an already done Benson Sleeved 81.5mm LS block for $500 less.
What would you guys do ?
Old May 12, 2005 | 09:19 AM
Default Re: NEED HELP WITH DECISION: GSR or LS Block??? (Da K00l Aid Mayun)
help?
Old May 12, 2005 | 10:44 AM
_entropy's Avatar
If you went with the LS block you'd need the vtec conversion kit, and new rods if you wanted to use the LS crank. IMHO it makes everything easier to just run the GSR block, the difference is only going to be around 250 dollars once you factor in getting the VTEC head on the LS block, so I'd personally go with the GSR.
Old May 12, 2005 | 10:58 AM
tony n.'s Avatar
Default Re: NEED HELP WITH DECISION: GSR or LS Block??? (Napoleon Dynamite)
gsr
Old May 12, 2005 | 11:02 AM
Default Re: NEED HELP WITH DECISION: GSR or LS Block??? (boosted2cam)
Thanks guys, I thought I had made the right decision and you proved me right
Old May 13, 2005 | 06:06 AM
Integra GSR 95's Avatar
gsr block
Old May 13, 2005 | 06:10 AM
B18C1CYA's Avatar
ls , the cranks are interchangable between the B series , you just need to use the rods that go with the crank
Old May 13, 2005 | 06:28 AM
Redwidow's Avatar
I'm LS but you have the choice I wish I'd made, which is to go with the GSR block With LS internals. It's more stroke and better and with the stock GSR oil squirters/girdle.
Old May 13, 2005 | 08:02 AM
Default Re: NEED HELP WITH DECISION: GSR or LS Block??? (Redwidow)
I am just going with the GSR bottom end.
It is having AEBS sleeves installed as we speak. I will post some dyno number in a few weeks once I have some runs down on race gas.
Old May 13, 2005 | 04:54 PM
_entropy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Redwidow &raquo;</TD></TR><TR><TD CLASS="quote">I'm LS but you have the choice I wish I'd made, which is to go with the GSR block With LS internals. It's more stroke and better and with the stock GSR oil squirters/girdle. </TD></TR></TABLE>
Oil squirters don't clear the GSR crank.
Old May 13, 2005 | 05:27 PM
B18Flip's Avatar
just go w/ the gsr bottom end since you already have it...you won't need the oil squirters anyway w/ forged pistons
Old May 14, 2005 | 02:44 AM
Redwidow's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Napoleon Dynamite &raquo;</TD></TR><TR><TD CLASS="quote">
Oil squirters don't clear the GSR crank.</TD></TR></TABLE>
Explain please...
Old May 14, 2005 | 07:22 AM
_entropy's Avatar
Explain please...</TD></TR></TABLE>
When I tested an LS crank in my GSR block the squirters didn't clear the counterweights.
escape2me
Jan 24, 2006 12:59 PM
arielmalespin
Apr 27, 2005 11:24 AM
LBDM EK97
12
Apr 12, 2005 03:58 PM
blmracing
Feb 25, 2003 10:15 PM
