Need help deciding which Civic radiator to get.
Old Apr 19, 2003 | 01:19 PM
swrdply400mrelay's Avatar
Default Need help deciding which Civic radiator to get.
My car is overheating; I'm buying a radiator next. Which one should I get?
I hear the PWR one has fitment problems on the 00 Civic.
I don't know how good the quality of each radiator compares with each other, especially C&R. I've only heard that PWR is better than Fluidyne, so how does C&R compare with the other two?
Thanks,
Mike
Old Apr 19, 2003 | 01:26 PM
Nine's Avatar
Default Re: Need help deciding which Civic radiator to get. (swrdply400mrelay)
Get a del sol dual core w/ fal fans.
Old Apr 19, 2003 | 02:27 PM
Default Re: Need help deciding which Civic radiator to get. (Nine)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nine &raquo;</TD></TR><TR><TD CLASS="quote">Get a del sol dual core w/ fal fans.</TD></TR></TABLE>
I kinda need AC. And I don't want to hear anything about AC's for wusses; it's for the ladies!
Old Apr 19, 2003 | 04:28 PM
CRVRX's Avatar
Everything fits the 00 civic OK , For the budget set up the 95 Del sol dual core . I would go with a Koyo or a C+R with a Spal fan , Then look at a lower temp thermostat. You should be OK then.
Old Apr 19, 2003 | 04:58 PM
inspyral's Avatar
Default Re: Need help deciding which Civic radiator to get. (CRVRX)
I like my PWR and FAL
Old Apr 19, 2003 | 06:27 PM
Midwestrider's Avatar
Default Re: Need help deciding which Civic radiator to get. (inspyral)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by inspyral &raquo;</TD></TR><TR><TD CLASS="quote">I like my PWR and FAL </TD></TR></TABLE>
I was looking at a PWR for my D16Y8.
Did you have any fitment issues with the PWR? I know they are made for the B-series.. What radiator hoses did you use?
Thanks
Eric
Old Apr 19, 2003 | 06:39 PM
Default Re: Need help deciding which Civic radiator to get. (Midwestrider)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Midwestrider &raquo;</TD></TR><TR><TD CLASS="quote">
Thanks
Eric</TD></TR></TABLE>
He told me he used GSR hoses and had to trim the brackets for the FAL fan a little.
Old Apr 19, 2003 | 06:44 PM
Humm so GSR hoses work just need triming..
I am will be using a pusher fan setup..
Thxs
Old Apr 19, 2003 | 07:08 PM
BoostedSi's Avatar
get a del sol dual core or 99-00 si radiator. It works fine.
Old Apr 28, 2003 | 12:08 PM
slcxow's Avatar
Default Re: Need help deciding which Civic radiator to get. (BoostedSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedSi &raquo;</TD></TR><TR><TD CLASS="quote">get a del sol dual core or 99-00 si radiator. It works fine.</TD></TR></TABLE> Is it a direct drop in for the del sol core in a 92 CX HB with a b16? My old stock radiator has a tiny hole on top where it is mounted. [IMG][/IMG]
Old Apr 28, 2003 | 12:36 PM
silverEH2's Avatar
pwr works great for me..........fitment is not a prob. it fits great......you can also bolt the stock fan onto it if it fits in your bay.
Old Apr 28, 2003 | 12:54 PM
hybridsol's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRVRX &raquo;</TD></TR><TR><TD CLASS="quote"> Then look at a lower temp thermostat. You should be OK then.
I bought the Mugen 170 deg t-stat. In the winter when I was n/a my car couldn't get warm enought to get out of open loop.
I still have it if anyone wants it.
[edit] i have the lower temp fan switch too. From inline-4
Old Apr 28, 2003 | 06:34 PM
alpha's Avatar
I went with a PWR radiator. I will probably buy a thin fan from Auto Zone or something along those lines. I have not installed it yet (waiting for the new block to be put in, head work and other stuff to get finished).
http://photos.yahoo.com/bc/alp...o.com/
Old Apr 28, 2003 | 07:20 PM
blkDOHCsol's Avatar
New User
Default Re: Need help deciding which Civic radiator to get. (0x64)
they sell dual core civic radiators at autozone..they are really good.
Old Apr 28, 2003 | 09:14 PM
tony1's Avatar
Default Re: Need help deciding which Civic radiator to get. (blkDOHCsol)
We run a c&r in our race car and i they are the best quality of the three. You can also get them with a spal fan already mounted on aluminum rails welded to the radiator. That's the way to go...
Old Apr 28, 2003 | 11:16 PM
FFDragger's Avatar
New User
Default Re: Need help deciding which Civic radiator to get. (tony1)
What's the difference between C&R's civic drag radiator and their regular radiators?
Old Apr 28, 2003 | 11:50 PM
Smashback's Avatar
All these big fat *** radiators are overkill for most people. If my LS turbo engine ran cool in Texas on a stock single core, a dual core should be more than enough for an SOHC.
But hey, if you've got money to burn, burn it! That's why they make those giant radiators
playahwitgame
Jun 19, 2006 10:34 AM
Syco Mike
Oct 31, 2005 06:08 AM
JMinSi2000
Jan 7, 2005 10:44 AM
a11mtrhatch
Dec 20, 2004 10:06 AM
