need help with building a z6 turbo
finally decided on which motor to do and chose the d16z6 since its an si and i own an si hatchback. i would like to know some build procedures and lists if anyone can help me to choose the right parts to build the car to 500whp is my max i dont want it more then that. and i'd like to keep it a daily driver please help any ideas would be greatly appreciated thanks.
The Grumpiest
Re: need help with building a z6 turbo
If you have to ask how to build a 500 horsepower car then you're not ready to build a 500 horsepower car. Do more research other than asking how to do it. How'd you even figure on 500 for horsepower? Do you think 500 HP is even streetable?
yeah i did research i even have a list of parts that i wrote down and what turbo to use i'd like some more input though in how to make it more efficiant i even talked to a guy who built his to 500whp and he has 1000cc injectors but the shop i went to said that 750cc injectors would work fine. so i did alot of digging i just want more info on it before i actually start. i've been digging about this for about 2-3 months even talked to bisimoto about the build. so i decided to join this forum and ask u guys. but telling me to do more research without asking what i already know isnt really helping. i asked for help not criticism
The Grumpiest
Even better. Do you honestly think you can squeeze 500 hp out of a D-Series engine? I almost spit out my drink when I realized you said that.
how do i figure cause of the injectors and how much gas it would eat if it was above 500
The Grumpiest
How about telling us what you DO know when you post? As it stands right now you are coming across as a straight noob. Like I said. If you have to ask at this point you aren't ready. Go check in the Forced Induction forum and they'll tell you the same thing. Better to have Bisi build it for you because YOU aren't getting that kind of power out of it.
The Grumpiest
Your first apparent build and you're trying ti build a race car for street driving? Doesn't sound realistic to me.
The Grumpiest
Shop i'm at told me to use 70mm throttle body and port flow the skunk2 manifold to match the throttle body for more power. what do u think? what size turbo u gonna be running? shop i was at told me to go with garret or turbonetics bb turbo with twin scroll. what do u think?
You don't even know if port matching a TB is gonna net you more power or not. Aaaaaand you don't even know what turbo you're going to run. Sounds like sound research to me.
what i wanna do is
crower valve springs and retainers plus valve guides
port and polish with a 3 angle valve job
then make the valves one size bigger
with a crower forced induction camshaft and an aem camgear
then i was told to run a skunk2 intake manifold and a 72mm throttle body and do a match flow on it
aem fuel rail with regulator
rc 750cc injectors
walboro 255lph feul pump
resleeve the block with darton sleeves and bore it out .2 over
use arias pistons and rings
micropolish and balance the the stock crank
eagle rods. acl bearings
arp head studs
gt-k 500 turbonetics turbo
s300 ecu
The Grumpiest
Yeah. Good luck with that. Should have posted this from the start. Still doubtful this is anything but a window shopping list. 500 daily driver. You make me laugh.
i was asking him what he thought about it not if it would or not. i know which turbo i wanna get i wanted to see what his opinion on which one was better smart guy
The Grumpiest
I ask one more time. Do you actually believe you are going to run 500HP as a daily driver? Show me anyone that is ACTUALLY doing that. 300-350 is more than enough for the street.
at the beginning of the post i stated 500hp max didnt state that i was gonna do 500.... wow read man. first of all second of all no ur right i'm gonna have a low boost and high boost tune on it i'm hoping to get it tuned to 325 or 350 on the street and whenever i come across a car i cant beat theres high boost to whichever hp range NO MORE THEN 500hp
posting up again. i wanna know and hear from people who have done a 500hp d series or close to 500hp it can be a 400hp single cam build on the parts they used and things they did to the head and block. i dont wanna hear from a person who doesnt even think 500 is possible on a d series. or wants to criticize me for what i wanna do and be an idiot on the post cause he thinks i wont do it or afford it not know me or what i can and cannot do so please anyone who knows anything and has done the build or is doing a build have any suggestions or comments bout how i wanna do it to help me not criticize me thanks. the list was posted earlier on what i have in mind for the motor if u think theres stuff missing or that can be changed for better parts let me know. thanks
Then have them help you out. If I had that kind of resource I would NOT be asking strangers on a forum. Also if you knew how they built theirs then use their builds as a guide.
i want the experiance in building it myself and to gain the knowledge of it and actually the thrill of doing it and when its done being able to say i built it not lie about it and be like yeah i built it and in all reallity all i did was pay some guy to do it. i want the experiance i love working on cars but i dont have alot of experiance in building them to go faster just to repair simple things
Yeah i got you. Well before you buy any parts... Buy some damn fine micrometers and bore guages. And read up on blue printing engines and checking bearing clearances. etc etc. Just get a grasp of what the ENTIRE process entails. Its fairly intimidating man haha
i have micrometers and all that stuff. went to school for machinist so had to get all the machining tools lol. the one thing i probably wont do myself is the machining part because i dont own the machines but i know the procedure. but like installing the pistons, rods, bearings, camshaft, springs, retainers etc i wanna do myself. one thing i'd love to learn is how to do dyno tunning
here again is my list of what i wanna do to get there
what i wanna do is
rc 750cc injectors
arp head studs
s300 ecu
koyo radiator
if i'm missing something let me know
what i wanna do is
rc 750cc injectors
arp head studs
s300 ecu
koyo radiator
you won't make 500hp on 750cc injectors. 750cc injectors are ideally sized for 350whp which by the way is a much more realistic and streetable goal with a d16
use the calculator at http://www.fuelinjectorconnection.co...widercalc.html
to select your proper size
if you really are going to push the HP it's almost cheaper to use a b18c since you won't need to do cams, gears or really any head work. bottom end parts cost similar so if you're going to buy the swap, it might be cheaper and more powerful to step it up
