need help - blowing ecu fuse
Old Mar 31, 2007 | 05:34 PM
BoostedSiRhc's Avatar
Default need help - blowing ecu fuse
ecu fuse (15 a) keeps blowing, i have aem, c2di, running c.o.p. injector driver etc. i rewired the engine harness but the fuse still pops. any place that i should also be looking at? the last thing i did before this happened is that i sanded down the paint and terminal at the grounding points
Old Mar 31, 2007 | 05:50 PM
eg crunkmonster's Avatar
Default Re: need help - blowing ecu fuse (BoostedSiRhc)
my o2 harness clip fell off and my o2 wires were touching and it kept blowing fuses. hope that helps, or bust out the handy voltage meter and start checking
Old Mar 31, 2007 | 06:03 PM
Default Re: need help - blowing ecu fuse (eg crunkmonster)
i dont have an o2 sensor/harness.. thanks for your help.
it sucks this would take a while to fix argh
Old Apr 1, 2007 | 02:48 AM
flangemastermike's Avatar
same i got my wires for my o2 sensor crushed between the gearbox and the engine when changed the cluch, that shorts out ur ecu fuse. good luck.
moss500
47
Apr 23, 2014 06:16 PM
alertik
Sep 6, 2008 01:53 PM
93NTEGLS
May 29, 2006 05:44 PM
beaterdriver
Mar 4, 2005 12:36 PM
94gsr_vtc
Oct 24, 2004 01:06 AM
