need help with blow off valve
Old May 28, 2009 | 05:38 PM
boostfever's Avatar
Default need help with blow off valve
okay...i took off my tial 50mm blow off valve to clean my pipings and now my blow off valve doesn't stay close when in idle. it opens up and you can hear it pretty loud
it only close when i rev up the car to make that ppsshhh noise and it opens right back up
Old May 28, 2009 | 07:30 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: need help with blow off valve
are you sure it wasnt like that before? my 50mm out of the box was open at idle also. i put a stiffer spring in there.
Old May 28, 2009 | 07:55 PM
got wide's Avatar
do you want it to stay shut when you let off the gas???? you know that ppsshhh noise is the sound of it opening and not closing right? as long as it shuts when you give it any throttle your fine. just go vvrrrooooomm ppsshhhhh up and down the street to your hearts desire.
Old May 29, 2009 | 10:13 AM
boostfever's Avatar
no when im on gas it stays open also. it only close when i led off the gas and makes that cool noise and open back up. i've check some of the tial 50mm bov on youtube and every single one of them is close when on idle.
Old Jun 3, 2009 | 08:24 PM
boostfever's Avatar
anyone?? how do i go about fixing this problem
Old Jun 3, 2009 | 09:11 PM
dpetro1's Avatar
What spring is in the bov? And how much vaccuum are you pulling at idle? My tial is cracked open slightly at idle with the 11lb spring. When under the hood, blip the throttle and see if it closes. If so then you are good to go.
Old Jun 4, 2009 | 05:51 AM
TiAL's Avatar
Originally Posted by boostfever
no when im on gas it stays open also. .
impossible unless you have a huge leak in the pressure feed line
Old Jun 4, 2009 | 06:32 AM
boostfever's Avatar
i have a 11lb spring and the vacuum reads 22 at idle. when i blip the throttle it stays open until i let off the throttle. i'll have video up by today on what im talking about. my car also idles really low on me when coming to stop and when im on gas the car stutters then picks back up with boost. need help asap
Old Jun 5, 2009 | 04:23 PM
boostfever's Avatar
[URL=http://s2.photobucket.com/albums/y15/Chai_n_Joyce/?action=view&current=153.flv][URL]
video is up of what im talking about
Old Jun 5, 2009 | 04:54 PM
boostedb20z's Avatar
thats what its suppost to do but it looks as you have a light spring in there but should be fine
Old Jun 6, 2009 | 04:42 AM
boostfever's Avatar
there's no way my bov should stay open and let air get in. this is how my bov should be which is close at idle. if you guys look at my video on top it stays open and not close like this one.
http://www.youtube.com/watch?v=LKWaevWlMjk
GsrIntegra789
May 9, 2009 10:16 PM
got wide
Oct 20, 2008 09:16 AM
JDMCRX
Jun 7, 2007 12:31 PM
Battle Mike
Jan 6, 2005 05:45 PM
