NEED HELP ASAP PLEASE
Old Nov 2, 2006 | 08:05 PM
mike93eh2's Avatar
Default NEED HELP ASAP PLEASE
ok im leaving here in a couple hours to head 7 hours away to chicago to get suprdave tuned.. he just got me the basemap today to fire it up for the first time.. got her fired up but my brand new aeromotive adjustable fuel press. regulator will not adjust!! its stuck on 75psi!!!!! what gives? should i take it apart? will a stock FPR be okay?
thanks guys!!
Old Nov 2, 2006 | 08:08 PM
95jeremie's Avatar
Default Re: NEED HELP ASAP PLEASE (mike93eh2)
need more info about you setup and power goals
Old Nov 2, 2006 | 08:11 PM
mike93eh2's Avatar
Default Re: NEED HELP ASAP PLEASE (95jeremie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95jeremie &raquo;</TD></TR><TR><TD CLASS="quote">need more info about you setup and power goals</TD></TR></TABLE>
everything you could ever need is right here...
https://honda-tech.com/zerothread?id=1786982
could a brand new aeromtive FPR be bad?? damn thing wont adjust the fuel psi!!
Old Nov 2, 2006 | 08:12 PM
D@nnY's Avatar
stock will be fine....make sure theres not a kink in the return line
Old Nov 2, 2006 | 08:18 PM
95jeremie's Avatar
Default Re: NEED HELP ASAP PLEASE (D@nnY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D@nnY &raquo;</TD></TR><TR><TD CLASS="quote">stock will be fine....make sure theres not a kink in the return line </TD></TR></TABLE>
Old Nov 2, 2006 | 08:19 PM
mike93eh2's Avatar
just found this...
https://honda-tech.com/zerothread?id=667691
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mista Bone &raquo;</TD></TR><TR><TD CLASS="quote">what aeromotive FPR you using??????????
On the Honda Rail mount units, the vacuum port fitting hits against the spring, locking it in place!
Aeromotive has NEVER returned my calls either!!!!!!!
stupid me for buying a fuel rail mount one.. damnit i wish i didnt get that one.
Old Nov 2, 2006 | 08:23 PM
AbitAvenger's Avatar
stock should be fine unless you need to bump fuel pres. up for lack of injector, which i think you should be fine. see if he can source one for ya real quick.
Old Nov 2, 2006 | 08:37 PM
mike93eh2's Avatar
son of a bitch.. expletive AEROMOTIVE!!!!!!!
the nipple has the spring jammed to the side and stuck!!! WTF! i thought aeromotive was the **** and i paid $200 or whatever for this!!?
Rudaluda
Nov 28, 2006 09:59 AM
highendmike
Apr 2, 2006 06:58 PM
PrecisionH23a
Jun 17, 2005 05:11 PM
ceasar of mgineering
May 29, 2005 11:46 PM
__37__
Sep 16, 2003 01:38 PM
