need help asap!! fuel cut at 6500
Old Mar 23, 2002 | 05:43 PM
Mr. Vapor's Avatar
Default need help asap!! fuel cut at 6500
Ok,
i installed my VAFC and AVCR today. All seems to work well, im not sure on what i should set it at. so i didnt mess aroudn to much, i just did what i thought i should do. but mostly its all stock settings. however, im getting FUEL CUT AT 6500 RPMS! i dont know why. i dont think its the VAFC, because we disconnected the fuel cut and it still got fuel cut. it gets fuel cut in neutral, as well as under load. im so confused. its really stressing me, does anyone have any ideas or thoughts?
310cc Injectors
8:1 FMU
DRAG KIT
7psi
b16 Civic Si
also im throwing code 41, primary heated 02 sensor, possibly shorted out or disconnected, havint investigated yet. but no other codes,
does anyone know if this is "Safe Mode" or what the charectoristics of safemode are? help please!
Old Mar 23, 2002 | 06:00 PM
phildeez's Avatar
Default Re: need help asap!! fuel cut at 6500 (NYb16)
im pretty sure your in limp mode so check the o2 sensor. I don't know why you get fuel cut you have any check valves or have a stand alone?
Old Mar 23, 2002 | 06:21 PM
AE86's Avatar
Default Re: need help asap!! fuel cut at 6500 (phildeez)
thats the beauty of obd 2. clear your check engine light and you should be fine
Old Mar 23, 2002 | 09:41 PM
Mr. Vapor's Avatar
Default Re: need help asap!! fuel cut at 6500 (AE86)
reset ECU, still got it.........
what should my basic settings on the VAFC be for my set up?
some ball park figures i can fine tweek?
narrow throttle? wide throttle etc etc
Old Mar 23, 2002 | 09:56 PM
Arturbo's Avatar
Better than steak
25 Year Member
Hmm, maybe you wired it up wrong? Dont know man..
art
Old Mar 23, 2002 | 10:02 PM
Ri5e's Avatar
Default Re: need help asap!! fuel cut at 6500 (Arturbo)
replace o2 sensor, possibly bad. my friend had the same problem, he replaced it and good bye problems!
Old Mar 24, 2002 | 01:09 AM
Mr. Vapor's Avatar
Default Re: need help asap!! fuel cut at 6500 (BG Boost)
Now,
the previous owner of this AVCR was a 300zx TT, i bought it off him. the 300z redline is right around 6500. is it possible that he had a limiter set in? does the AVCR have this ability? i just thought of this in the middle of hte night (it 5am here) it feels honest to god like redline at 6500, i lost 1500 rpms of my rev band. what do you guys think?
Old Mar 24, 2002 | 03:58 AM
niedejb's Avatar
Make sure its set up for a 4 cyl.
On the etc. menu, car select, make sure its got a 4 instead of a 6.
Old Mar 24, 2002 | 04:44 AM
Mr. Vapor's Avatar
Default Re: need help asap!! fuel cut at 6500 (niedejb)
yea it was on 6, we set it to 4 and still had the problem. but is there a way that he might have set the redline or fuel cut to 6500, i know this ******* AVCR can do that, this thing is so advanced!
Old Mar 24, 2002 | 11:17 AM
Mr. Vapor's Avatar
please!!!!!!!!! austrianR, you have one dont you?
Slain
Apr 18, 2007 12:06 AM
GTEC913
Jun 1, 2005 12:13 AM
c1civic
May 30, 2004 10:21 AM
Litoman
Aug 15, 2002 07:53 PM
oryanh
Jan 1, 2002 11:36 AM
