NEED HELP ASAP
Old Aug 17, 2009 | 07:34 PM
h22bomb's Avatar
Default NEED HELP ASAP
I have a b16 sir motor with a garrett super 60 that i just recently traded my h22 accord for, and i have a major problem.
Was driving down the road and at about 5000rpm i see and smell a bit of smoke, pull over the car stalls, check all around and their is oil on the block, and some on the down pipe, oil is on the bottom of dipstick but not empty.
Cant see where the leak came from as its dark on the side of the road but i check fuel, fire, have both. I take the plugs out they look mint, but car just rolls over and wont start.
I thought if detonation happened id hear it and plugs would be messed up, but no. Also not completely sure but when ever i hit 6000rpm it sounds like a fuel cut off, thought it was over boosting and this was a boost cut off programed into the computer for safety (tuned with uberdata).
possibly most importantly the vacuum line came off the waste gate but wouldn't boost cut protect that from infinite boost, and i think i only hit 6000rpm 2 times, accidentally (not used to driving a car that only went to 6)
SOMEONE WITH MORE KNOWLEDGE PLEASE HELP
Old Aug 17, 2009 | 08:05 PM
boost4s2k's Avatar
Default Re: NEED HELP ASAP
Old Aug 17, 2009 | 08:14 PM
beaneg6's Avatar
sounds like you blew your motor
Old Aug 17, 2009 | 09:43 PM
jdm inc's Avatar
you should do a compression test and see how it looks.
Sounds like the motor might be though.
Old Aug 18, 2009 | 01:13 PM
h22bomb's Avatar
going to do a leak down test tonight, hopfully the timming jumped and all i have is a couple of bent valves, and not a hole in the piston.
Old Aug 18, 2009 | 02:00 PM
boost4s2k's Avatar
well good luck with that ya never know might just be the fuel pump fuse haha (one can only wish)
Old Aug 18, 2009 | 05:35 PM
jdm inc's Avatar
Good luck let us know how it turns out.
Old Aug 18, 2009 | 07:38 PM
h22bomb's Avatar
was getting bad leak down into oil pan, ripped the head off tonight, top of pistons and valves are good, think i cracked ring landings, b16s are bad for that.
So i am leaving this Thursday to got home 17hour drive, decided to get a JDM B18B for 700 throw it in tomorrow and leave the next day with the b18 not turboed, as i dont have time to rebuild until i am home.
Motor doesn't come with wiring harness so i should be able to use mine, most b16's and b18b's are obd 2 so it should all be plug and play with a new b18b computer right....
Old Aug 18, 2009 | 07:39 PM
h22bomb's Avatar
And yea the timming did jump as well....fuc*ed up luck i got.
h22bomb
Aug 17, 2009 08:36 PM
d16y8delsol
Dec 15, 2005 08:54 PM
shermanyang
Aug 6, 2004 10:28 AM
shermanyang
Aug 5, 2004 09:00 PM
hatchback19
Jun 12, 2003 06:09 PM
