Need help
Old May 13, 2003 | 09:39 PM
Bspec18's Avatar
Default Need help
Lately when im in boost and at idle the car would surge for like a sec as if it might stall. on the Air/fuel ratio gauge you can see a solid sweep in lean when it happens. the car has been getting worse when it first started happing. I thought it could be overheating but all the cooling components are brand new. Everything under the hood looks good so what could it be ? Im thinking of adding a relay to my inline fuel pump just make sure im getting all 12 volts since it might be a fuel issue. and i've been smelling something under the hood is it possible that my cat just crapped out on me ? its still stock
Also i've been getting a CEL like once a week it is
code 54
CKF Sensor (Crankshaft Speed Fluctuation) defective circuit or unplugged / defective sensor
can anyone help point me to the right direction ?
Old May 13, 2003 | 10:01 PM
Bspec18's Avatar
Default Re: Need help (Bspec18)
awww.....cant some one help ?
PURPLETERROR aka BIGMATT
May 21, 2006 09:03 AM
iowarex72
May 27, 2004 02:22 PM
shivic
Apr 23, 2004 10:52 AM
