Need Fuel management advice ASAP
Old Aug 18, 2004 | 05:38 PM
NuRv's Avatar
Default Need Fuel management advice ASAP
I put together a turbo kit for my 95 GSR. It is a ssautochrome manifold. Watercooled t3/t4 not sure the rim. 30x6x3 FMIC,HKS SSSQ BOV and a Tial 38mm wastegate. My goal is 9 pounds of boost on a stock motor. I have a drag car and want a reliable daily driver. What type of fuel management will attain my goals while not spending an arm and a leg on a standalone. Thanks for your help
Old Aug 18, 2004 | 05:45 PM
redrocketgsr's Avatar
Default Re: Need Fuel management advice ASAP (NuRv)
uberdata.....i love it, cost about 30 dollars to get ECU ready, then 80 dollars for a burner to change whatever you want. and since your OBDI you have the best ecu for it anyways.
Old Aug 18, 2004 | 05:52 PM
NuRv's Avatar
Default Re: Need Fuel management advice ASAP (redrocketgsr)
What size injectors will i need and will I need and FMU and fuel pump. I heard to do it right would be to leave out the FMU and get the right size injectors and fuel pump, Is that right?
Old Aug 18, 2004 | 06:22 PM
johnmay19's Avatar
I would suggest 550's just so you have some room to grow. Correct you will not need the Fmu, just a walbro 255.
Old Aug 18, 2004 | 06:29 PM
toolowsol's Avatar
Default Re: Need Fuel management advice ASAP (johnmay19)
I'm runnin uberdata, it is fantastic, I've spent about $550 on my fuel and timing management.
Uberdata: FREE
rom buner: $80
DSM 450s + resistor box $75
Walbro intank $90
Chips and supplies $20
PLX M300 wideband $300
Total: $565
stussy8280
Sep 5, 2005 06:31 PM
gtowni3
Mar 17, 2004 07:59 PM
sneakypete
Mar 26, 2003 04:08 PM
dave'sh22a4
Dec 9, 2002 05:01 AM
T3EMSI
Jun 5, 2002 08:30 AM
