Need expert opinion on turbo setup
Old May 22, 2007 | 01:23 PM
Spoolind16's Avatar
Default Need expert opinion on turbo setup
I have a 95 LS swapped civic and I plan on going turbo in a month. I found a turbo that a friend is selling that seems large for my setup but is at a really good price. My goals are 300whp on pump gas with decent spool time and less than 20psi. This will be done on stock internals.
The turbo specs are as follows:
Type: t3\t04b
Compressor A/R - .60 and I believe the trim is 60 as well
EXHAUST A/R - .84
EXHAUST WHEEL DIAMETER - 58mm.
COMPRESSOR WHEEL DIAMETER - 49mm.
My questions are as follows:
1. Will this turbo fit my needs or is it to big\small?
2. Will this turbo choke out up top (7k rpm)?
3. Will this turbo spool at a decent rpm assuming I run a 3 inch exhaust?
Thanks for your help guys
Old May 22, 2007 | 01:56 PM
da_dude's Avatar
That .84 a/r is too big for your setup. A .63 a/r will suite you better.
Old May 22, 2007 | 02:41 PM
Spoolind16's Avatar
Default Re: (turb20_vtec)
K, Anyone else care to offer their 2 cents
Old May 22, 2007 | 04:59 PM
1158's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turb20_vtec &raquo;</TD></TR><TR><TD CLASS="quote">That .84 a/r is too big for your setup. A .63 a/r will suite you better.</TD></TR></TABLE>
X2
But if you could find a .63 a/r someone is selling or wants to trade for a .84 you might still make out.
Old May 23, 2007 | 10:01 PM
Spoolind16's Avatar
Default Re: (1158)
Thanks this helps
speedjunkie_g35
Jan 7, 2012 05:14 PM
shawn_crx
Nov 3, 2003 07:46 AM
AsianMullet
Oct 25, 2003 11:56 AM
sohcvtec1995
Sep 16, 2003 12:05 PM
