need advice on this turbo
Old May 20, 2009 | 04:24 PM
Kr4nG's Avatar
Default need advice on this turbo
i just bought this percision gt35r turbo from a fellow honda tech member. but im having second thoughts about it because i think its too big for my gsr. the sizes are .58 ar and the .70 ar intake housing. i havnt opened it up yet but he said its a dual ball bearing.
Old May 20, 2009 | 04:31 PM
omgwtfbbq's Avatar
Default Re: need advice on this turbo
Is your GSR stock?
Old May 20, 2009 | 05:28 PM
Kr4nG's Avatar
Yes except the ctr cams and I will upgrade the valve springs too
Old May 20, 2009 | 07:58 PM
TheShodan's Avatar
Moderator
DO NOT attempt to crack it open, or you'll be with nothing but a paperweight. That's a big turbo, GT35R or not, so it depends upon what you're trying to do for power.
Old May 21, 2009 | 02:23 AM
Kr4nG's Avatar
why do you say that. why cant i open it. then how am i suppose to replace the bearings.
Old May 21, 2009 | 05:03 AM
marcj's Avatar
how much did you pay? if you paid anything more than $200 you got ripped off pretty bad.. it's going to cost you more than $600 to repair correctly.
Old May 21, 2009 | 05:30 AM
WDG_729_ITR's Avatar
lol I wouldn't say it's too big...but it would be best to have a built motor for something that powerful.
Old May 21, 2009 | 01:31 PM
Kr4nG's Avatar
that was the price 200 shipped to my door. how expensive are these parts. and why should i not open it. where can i get the rebuild kit from.
thanks
Old May 21, 2009 | 01:49 PM
TheShodan's Avatar
Moderator
You can't replace the bearing system in a True GT35R. Only the journal bearing version. That is why you should not "crack" it open.
Old May 21, 2009 | 03:26 PM
Yeah if you try to crack it open you could be throwing the money you spent on it, right down the drain.
Old May 21, 2009 | 03:37 PM
marcj's Avatar
the rebuilds for the DBB cost 700+, 700+200 would get you a new or low mile GT35R
Old May 21, 2009 | 04:00 PM
bump
Old May 21, 2009 | 04:55 PM
Kr4nG's Avatar
True well I opened it up and it's Jernal bearing I just need new seals and probably a new exhaust fins/shaft if I can't fix it. Thanks for all the info I'll see wat happens
tony_2018
Sep 2, 2016 05:52 AM
m00genwant2b
Apr 22, 2011 08:47 AM
EG_SINZ
Dec 15, 2010 08:35 PM
redtegra
Jul 5, 2009 07:59 PM
Pikachu
Mar 14, 2005 09:12 PM
