Quick 35mm TIAL + Profec B vaccum question...
I notice some people using the top nipple with boost controllers... some aren't. I hooked up a Profec B today using only the side nipple to the actuator box... with the other nipple on the box going to manifold vac, as well as the controller in the car going to manifold vac... and everything seems to work fine. This ok?
Re: Quick 35mm TIAL + Profec B vaccum question... (HybridKOOP)
the Solenoid - "Out" connects to the top of the wastegate. "In" = Vacuum/boost source, could be from the turbo (Before throttle plate) or after (Intake manifold).
Re: Quick 35mm TIAL + Profec B vaccum question... (BG Boost)
I dont use my top port with the Profec. The in is from the compressor and the out goes to the side of the tial.
