necessary gauges for boost...
Old Jun 8, 2004 | 12:55 PM
jDMJeRk's Avatar
Default necessary gauges for boost...
What gauges are necessary for boost?
-boost gauge
-oil pressure
-a/f ratio
Old Jun 8, 2004 | 12:59 PM
RobbieG35's Avatar
12 Years Strong
Default Re: necessary gauges for boost... (jdmjerk)
Boost, oil pressure, and EGT
Old Jun 8, 2004 | 01:06 PM
jDMJeRk's Avatar
Default Re: necessary gauges for boost... (HybridHatch88)
whats EGT?
Old Jun 8, 2004 | 01:13 PM
USDM 4G VTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmjerk &raquo;</TD></TR><TR><TD CLASS="quote">whats EGT?</TD></TR></TABLE>
Exhaust Gas Temp
good tunning tool on the dyno to find out if u have the right AFR and ignition timing
Muckman's Avatar
Moderator in Chief
Exhaust Gas Temp
Wasnt this gauge question already asked today?
https://honda-tech.com/zerothread?id=889032
Old Jun 8, 2004 | 01:16 PM
Pengo's Avatar
boost and oil press is good enough for me.
fuel press depending on fuel system
Old Jun 8, 2004 | 01:21 PM
aznballer's Avatar
boost, egt, wideband o2
Old Jun 8, 2004 | 01:30 PM
jDMJeRk's Avatar
Default Re: (aznballer)
I didnt even know there were all these gauges. I dont have 10 spots for gauges.
-What are the for sure necessary ones
-how many gauges do most people have
-since you can see what your a/f is from a dyno is it not necessary to have a a/f
-I wasnt going to get a wideband ill just use the shops for tuning
Old Jun 8, 2004 | 01:34 PM
EJ1 wilcox's Avatar
Default Re: (jdmjerk)
I'm going with...
-oil pressure (always good insurance)
-boost (gotta have the boost gauge!)
-wideband o2 (I'm going to "street tune" my car w/ VAFC, this will be cheaper for me than going to a shop and doing it there.)
If I were going to just take my car to a shop and have them do the tuning, I would just get oil pressure and boost, you don't need one of those autometer light shows
Old Jun 8, 2004 | 02:27 PM
iiilgsrlll's Avatar
Wouldn't the EGT be a little redundant if you're running an A/F gauge? (Assuming its a wideband)
Old Jun 8, 2004 | 03:22 PM
Boofster's Avatar
Default Re: necessary gauges for boost... (iiilgsrlll)
A/F gauge doesn't mean crap. Just rainbow light show.
Boost + Oil pressure are absolutely necessary. If you lose oil pressure, get your *** off the road right away.
EGT is nice to keep tabs on. Should tune at dyno anyway but wideband costs a fortune if you want that to tune in real time.
After proper tune, you shouldnt worry about fuel pressure but have one on the fuel rail for idle baseline especially with bigger injectors.
Old Jun 8, 2004 | 03:28 PM
iiilgsrlll's Avatar
Default Re: necessary gauges for boost... (Boofster)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boofster &raquo;</TD></TR><TR><TD CLASS="quote">A/F gauge doesn't mean crap. Just rainbow light show.
Notice I was referring to a wideband a/f gauge. If you're referring the Autometer one then I totally agree with you that its useless.
Old Jun 8, 2004 | 05:04 PM
Haberdasher's Avatar
There is also a boost gauge on the steering column.
The Autometer A/F gauge is for MONITORING. That is what it was designed for, that is what it is good for, that is why you should have one.
Old Jun 8, 2004 | 05:06 PM
96-EJ6 B18C's Avatar
Default Re: necessary gauges for boost... (Haberdasher)
I just run boost and a wideband
Old Jun 8, 2004 | 05:07 PM
boosted92's Avatar
I'm running boost/oil pressure/fuel pressure along the a-pillar. Those are the absolute necesities, IMO. If I want to check on anything else i'll bring my laptop around and run the digital dash with the AEM.
Old Jun 8, 2004 | 06:01 PM
SiRex91's Avatar
Default Re: necessary gauges for boost... (boosted92)
IMO, Boost, Oil Pressure and EGT are the most important three gauges for turbo cars.
Old Jun 8, 2004 | 06:02 PM
XXXRacing's Avatar
Default Re: necessary gauges for boost... (SiRex91)
got a brand new EGT for sale for cheap: https://honda-tech.com/zerothread?id=889773
Old Jun 8, 2004 | 06:11 PM
Charles B.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmjerk &raquo;</TD></TR><TR><TD CLASS="quote">how many gauges do most people have</TD></TR></TABLE>
right now i only have one (boost). it's more than enough to just get you started. in the future i will have more than one, specifically the ones mentioned above.
Old Jun 8, 2004 | 06:15 PM
Sohc Driver's Avatar
Default Re: (CharlesInTurbocharge)
I'll be running Greddy:
1. Boost
2. Egt
3. Oil pressure
4. Water Temp
Old Jun 8, 2004 | 06:17 PM
djfob's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiRex91 &raquo;</TD></TR><TR><TD CLASS="quote">IMO, Boost, Oil Pressure and EGT are the most important three gauges for turbo cars. </TD></TR></TABLE>
these are what I'm running on a pillar
Old Jun 8, 2004 | 06:25 PM
Smooth-GSR's Avatar
Default Re: necessary gauges for boost... (djfob)
I have boost and egt on my cluster mount and am looking for an oil pressure one, just have to find somewhere to put it.
Old Jun 8, 2004 | 06:41 PM
boosted-delslow's Avatar
Default Re: necessary gauges for boost... (Smooth-GSR)
I'll be using a boost guage and PLX devices wideband!!!
Old Jun 8, 2004 | 07:38 PM
Si[R]'s Avatar
Default Re: necessary gauges for boost... (boosted-delslow)
boost, EGT, Oil press
Old Jun 9, 2004 | 12:27 AM
jDMJeRk's Avatar
Default Re: necessary gauges for boost... (Si[R])
I think after tuning the only ones that are NEEDED are:
-oil pressure
-water pressure
-boost
Please if you want to prove me wrong DO IT. I want to make sure I have the right ones for a REASON. Were here to argue in a good way
Old Jun 9, 2004 | 05:04 AM
FwdCivicHatch's Avatar
I think I'd rather have water/coolant temp, than water/coolant pressure....
