is it necessary to balanced engine parts ???
Old Jan 19, 2004 | 01:51 PM
Cyber ITR's Avatar
Default is it necessary to balanced engine parts ???
im currently rebuilding my engine , full resleeved , je , eagle
i just wondering if its necessary to balanced them , including the crank
thanks
Old Jan 19, 2004 | 02:02 PM
951's Avatar
951
Default Re: is it necessary to balanced engine parts ??? (Day Walker)
balancing your crank wouldnt be a horribly bad idea. but im not sure if you could deem it necessary. an unbalanced reciprocating assembly will turn vibration into an oscillating hammer. the faster the engine moves, the more mass behind the hammer. Simply put, dynamic balancing reduces the vibrations. ask the manufacturers, im sure they'll know if the rods will cause imbalance in an otherwise stock bottom end.
Old Jan 19, 2004 | 02:08 PM
Teglove2's Avatar
ALWAYS have your bottom end balanced! It's only a couple hundred and it's money well spent. Just because you buy new pistons, rods doesn't mean they're balanced. They will always be a little off. I know I work for Wiseco Piston. Have it done.
Old Jan 19, 2004 | 02:57 PM
grndcont's Avatar
ya, its cheep enuf to where you might as well do it.
Old Jan 19, 2004 | 03:00 PM
Irishweird00's Avatar
Banned
Default Re: (grndcont)
Honda cranks come balanced already.... Unless you are taking to high rev levels.... or high boost levels, I don't see the need for it... but It is cheap, and if the motor is torn down already, it isnt a bad idea to have it done. 150 bucks could get you a completely balanced and micropolished crank.
Old Jan 19, 2004 | 03:05 PM
EFb18b's Avatar
Default Re: (Irishweird00)
I'm not sure how far you are going into your bottom end but, if you bought new rods and pistons and are going to be using an aftermarket flywheel and clutch, then yes have it balanced. Especially if you are going to hitting high rpm. A decent machine shop will ask for the following to balance your crank:
Crank
pistons and rings
rods
rod bearings
flywheel
pressure plate
harmonic balancer
and anything else that is part of the rotating assembly
Old Jan 19, 2004 | 03:14 PM
Banned
Default Re: (Redlineracer)
Talk to Earl... He knows the deal...
ITRnorway
Aug 28, 2006 02:00 AM
ITRnorway
Aug 12, 2006 02:08 AM
95GSRTT
Sep 2, 2005 06:49 AM
LudeyKrus
Nov 12, 2003 05:37 PM
Trajic
Sep 5, 2001 08:28 AM
