Is my tial busted
Old Mar 10, 2004 | 09:58 AM
nevin's Avatar
Default Is my tial busted
when you take the spring out can you move the valve up and down easily? Mine takes alot of force to move.
Old Mar 10, 2004 | 10:03 AM
b18bturbo's Avatar
Default Re: Is my tial busted (nevin)
it sticky like that should be no problem the tial valves will work better with time
Old Mar 10, 2004 | 11:29 AM
nevin's Avatar
Default Re: Is my tial busted (b18bturbo)
I was in a accidnt and it broke off the manifold and was laying in the street.
I think theres somthing wrong with one of these two parts. They both look perfectly straight though.
Now when it gets to here it gets really hard to move, like tap it with a hammer to get it in/out.
Old Mar 10, 2004 | 12:19 PM
B18EG6's Avatar
to see if its bent, put the small end in a drill and spin it.... sometimes you cant see with the nekked eye.
Old Mar 10, 2004 | 12:22 PM
Mad Cow's Avatar
Default Re: Is my tial busted (B18EG6)
Or roll it accross a flat surface, the more it's bent the less it woll roll smoothly.
Old Mar 10, 2004 | 12:27 PM
nevin's Avatar
Yeah i stared at it for a good 20 mins, rolled it on the counter.. i could swear its flat lol. il try the drill thing
Old Mar 10, 2004 | 12:48 PM
racerxadam's Avatar
Default Re: (nevin)
my valve moves completely freely with the spring out. i good test would be to put it together and use a regulated air source to give the valve similar pressures to what you will be running and see if it opens and closes freely.
Old Mar 10, 2004 | 05:00 PM
nevin's Avatar
ya i tried that and it didnt close, thats why i thought it was broken.
Old Mar 10, 2004 | 05:56 PM
Cramerox's Avatar
Default Re: (nevin)
do they sell replacement parts for Tial WG's?
Adriano's Avatar
Default Re: (nevin)
That valve is supposed to move freely. The only tension it should havei s from the spring. It's probably no good.
Old Mar 10, 2004 | 08:05 PM
nevin's Avatar
Default Re: (brryder)
yeah thats what I was thinking. thanks for the replies. I will try contacting tial.
tfnaaf
May 9, 2005 03:11 PM
rideblitz
Oct 28, 2004 08:13 PM
busakiller
Jul 22, 2004 05:12 PM
420aNT
Mar 5, 2003 04:44 AM
ezark
Oct 2, 2002 12:34 PM
