My Skunk2 Throttle Boddy is leaking!
Old May 26, 2013 | 07:29 AM
Steeve_Civic's Avatar
Default My Skunk2 Throttle Boddy is leaking!
When I put pressure in my Intake line from Turbo (in order to control my leaks) my SkunK2 Pro Billet 70mm brand new, is leaking at the Throttle??
Is it normal or my TB is suck?
Old May 26, 2013 | 07:49 AM
rich7777's Avatar
Default Re: My Skunk2 Throttle Boddy is leaking!
Can you pin point exactly where it is leaking? It shouldn't leak.
Old May 26, 2013 | 08:00 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
He is talking about the throttle plate shaft most likely.
Just how bad is it leaking? A small amount is normal, but also depends on how much pressure you are applying to it. Do you have a different throttle body you can install to compare?
Old May 26, 2013 | 08:50 AM
Yes just at the plate shaft.
I put 32 PSI in the line.
NO I do not get another TB.
I'll try to put a vid If I can
jiggacivic
Aug 9, 2011 10:22 AM
cranker
Jul 22, 2010 11:39 PM
Spectrum24x
Feb 12, 2006 04:29 AM
misterpsycho
Apr 14, 2005 10:47 AM
asefi944
Apr 11, 2005 09:43 PM
