My sidewinder install, clearance issues
Old Apr 20, 2004 | 07:24 AM
  #26
DaX's Avatar
DaX
Loved
Community Favorite
I'm using a short piece of 1.5" mandrel bent tubing coming off my dump flange and then am using 1.5" flex hose from JCW. Are you facing your dump to the front or rear of your car?
Old Apr 20, 2004 | 08:02 AM
  #27
dasher's Avatar
Default Re: (DaX)
I bought a bunch of 90 degree stainless steel bends from mcmaster and some pipe... going to send it to the rear and have it pipe slant down at a 45 degree angle touching the starter towards the rear of the car and out near towards the end of the downpipe.... its going to be an open dumptube with 2 lawn mower muflers attached for noise
Old Apr 20, 2004 | 08:54 AM
  #28
DaX's Avatar
DaX
Loved
Community Favorite
So the mouth on your Tial is pointed toward the rear of the car? You're going over the transmission with your dump?
Old Apr 20, 2004 | 09:11 AM
  #29
dasher's Avatar
Default Re: (DaX)
mouth towards the rear, yes...
going over my tranny.... will not dump on my tranny... sending it all the way back and down.. away from my tranny to the underside of the car
Old Apr 20, 2004 | 04:53 PM
  #30
DaX's Avatar
DaX
Loved
Community Favorite
I'm facing my gate toward the front [for now] and I'm going to get 5 feet of the flex hose...I'll dump however far that will let me go.
Old Apr 21, 2004 | 10:18 PM
  #31
dasher's Avatar
Default Re: (DaX)
changed my mind on the dumptube (To much clearance issues on my first proposal)....
facing the wastgate towards the rear of the car ... here how its going to run:
Wastegate - 90 turn towards passenger side side wall -- steel pipe goes through hole cut in sidewall --- 90 down dump (where the stock intake resonator used to be located )...
oh and by the way .. Its already been welded and completed .. so its done and works great
Old Apr 22, 2004 | 05:29 AM
  #32
DaX's Avatar
DaX
Loved
Community Favorite
I would love to see pictures...I'm still unsure as to how I want to run mine. I have mine facing forward for the time being.
Old Apr 22, 2004 | 07:18 AM
  #33
dasher's Avatar
Default Re: (DaX)
i'll get you some pics later(really busy today).. i couldn't face it forward because of the radiator hose interference ....
Here is how I worked out the radiator hose deal :
1- cut the radiator neck in half and sanded down the the tabs on the neck to make sure the radiator hose has at least 1 inch to grab onto.
2)Pull the radiator as far forward as could so it touches the front
3) got 3 90 staineless steel bends 1" od and welded them together as follows .... 90 degree to the left(passenger ),90 degree to the down , 90 degree right side up... so the staineless steel pipe curves around and touches the wastegate and exits slightly lower then the end of the wastegate for a radiator hose to attach to .
Old Apr 22, 2004 | 07:23 AM
  #34
DaX's Avatar
DaX
Loved
Community Favorite
Default Re: (dasher)
Yeah I'd love to see pictures. The upper radiator hose is my next obstacle. I was thinking of just going over the manifold with a straight piece of aluminum pipe and then radiator hose on each end of the pipe to connect it to the engine and to the radiator. I don't know if this will work though, because the heat from the manifold may cause the coolant to boil [as if it isn't hot enough already]. I would definately wrap the metal coolant pipe piece to protect it from rubbing against the manifold. But yeah, I want to see other sidewinder owner's solution to the upper radiator hose. Lower radiator hose is fine, right?
Old Apr 22, 2004 | 07:30 AM
  #35
dasher's Avatar
Default Re: (DaX)
yeah lower radiator hose is perfect ... no changes needed .
...I didn't send it above the sidewinder because it seemed that there would be clearance issues with the hood (the hybrid swap make the engine sit higher ) and I didn't want the pipe to touch the manifold -- despite the manifold being ceramic coated .
I'll see if I can email you some detailed pics late tonight when i can grab a digi cam
Old Apr 22, 2004 | 07:31 AM
  #36
DaX's Avatar
DaX
Loved
Community Favorite
Much appreciated man.
Old Apr 22, 2004 | 07:35 AM
  #37
dasher's Avatar
Default Re: (DaX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaX &raquo;</TD></TR><TR><TD CLASS="quote"> I was thinking of just going over the manifold with a straight piece of aluminum pipe and then radiator hose on each end of the pipe to connect it to the engine and to the radiator. </TD></TR></TABLE>
Whatever you do ... do not use aluminum pipe !!! Aluminum is an excellent conductor of heat and you are going to end up boiling you water if it touches your manifold .... For that matter don't use mild steel either... it doesn't insulate as well as staineless (thats why mild steel headers come ceramic coated and staineless steel doesn't -- they don't need to.) ... use stainless only !
Old Apr 22, 2004 | 07:41 AM
  #38
DaX's Avatar
DaX
Loved
Community Favorite
Gotcha. Glad I know now.
Old Apr 22, 2004 | 08:05 AM
  #39
GSRwBOOST's Avatar
Default Re: My sidewinder install, clearance issues (93dx--hatch)
I'm on a dual T1 and your pictures jerked my machine to a slow crawl..
resize them...
heaven forbid someone click on this thread with anything less than a T1
Old Apr 22, 2004 | 02:00 PM
  #40
Short Round's Avatar
Default Re: My sidewinder install, clearance issues (GSRwBOOST)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSRwBOOST &raquo;</TD></TR><TR><TD CLASS="quote">
heaven forbid someone click on this thread with anything less than a T1</TD></TR></TABLE>
&lt;--- adelphia LOL
Old Apr 23, 2004 | 04:02 PM
  #41
93dx--hatch's Avatar
Default Re: My sidewinder install, clearance issues (Short Round)
anyone run an oil return on a sidewinder yet?
Old Apr 23, 2004 | 08:35 PM
  #42
dasher's Avatar
yeah it touches the DP... you are going to want to sleeve it with some fire proof insulating hose..
Old Apr 23, 2004 | 09:19 PM
  #43
Default Re: My sidewinder install, clearance issues (dasher)
yeah I was gonna run a rubber hose but the 3 inch downpipe is sort of in the way, I think i have some fire proof insulating that i used on the fire wall of my bug,
I should be running tomarrow night, hondata and injectors came today
Old Jun 1, 2004 | 09:16 PM
  #44
DaX's Avatar
DaX
Loved
Community Favorite
Getting close:
Old Jun 2, 2004 | 04:53 AM
  #45
dasher's Avatar
Default Re: My sidewinder install, clearance issues (DaX)
looks good dax ...
garados
Jun 18, 2007 11:52 AM
95whitegizzer
Jun 28, 2006 09:47 AM
hotimportcrx
Feb 24, 2005 10:17 AM
PhantomSTi
Jun 16, 2004 07:06 PM
InfamousRS
Jan 29, 2002 06:36 AM
