Is my setup safe for my engine?
Old Feb 24, 2004 | 06:10 PM
dan89crxsi's Avatar
Default Is my setup safe for my engine?
I am planning on running a D16a6 with a Y8 Head and manifold, IHI RHB5 turbo internally wastegated at 8 psi, 450cc injectors, FMIC, Ghettodyne w/ a custom binary file to run the 450cc injectors and retard the timing in boost. The binary file is set up very well to run the 450's and modify fuel and spark under boost. Do you think this is a safe setup for the high compression my mini me will be putting out? I am using stock pistons and rods in my d16a6.
Modified by dan89crxsi at 10:21 PM 2/24/2004
Old Feb 24, 2004 | 07:10 PM
dan89crxsi's Avatar
Default Re: Is my setup safe for my engine? (dan89crxsi)
noone has an opinion on my setup?
Old Feb 24, 2004 | 10:58 PM
Robzible's Avatar
hell yeah man , i think you will be just fine, because you still wont have as much compression as like say a b series vtec.. right? i think it will be ok with some fine tuning
Old Feb 25, 2004 | 01:53 PM
dan89crxsi's Avatar
Default Re: Is my setup safe for my engine? (Robzible)
i hope so cause i blew a rod through my last motor but that wasnt from boost heheh
Old Feb 25, 2004 | 02:00 PM
ndogg's Avatar
make sure you tune your "custom binary file" or at least put a WB on there and make sure you aren't too far off.
Old Feb 25, 2004 | 09:28 PM
blackeg's Avatar
Default Re: Is my setup safe for my engine? (ndogg)
ndogg is right- id suggest a wideband too to keep a real good eye on things. if u experience detonation or running lean, go back and do some program editing.
Old Feb 26, 2004 | 08:47 AM
dan89crxsi's Avatar
Default Re: Is my setup safe for my engine? (blackeg)
I think I am going to hook up a cable to my ecu for datalogging
Old Feb 26, 2004 | 11:13 AM
BoostedSi's Avatar
yes it will be safe as long as it gets tuned for a conservative amount of power
91_shoebox_Si
Aug 27, 2009 06:12 PM
killakalipoph
May 20, 2009 09:44 AM
CRX SIR
Jun 5, 2007 02:44 AM
phatrick2332
Sep 9, 2003 11:15 AM
94TealGSR
Jun 5, 2003 08:54 AM
