my rad fluid is evaporating...
Old Aug 3, 2006 | 03:03 PM
sirguy01's Avatar
Default my rad fluid is evaporating...
so i ahve topped my rad reservoir 3 times in the last month which is 3 times more than i have in the last 1 year after my build. Its been crazy hot here lately not sure if thats a reason why, there are no leaks, hoses have no residue, no white smoke naahhthing...
question... where is this rad fluid going? i can't figure it out...
ideas?
Old Aug 3, 2006 | 03:12 PM
earl's Avatar
Default Re: my rad fluid is evaporating... (sirguy01)
Put on a new radiator cap and your problem will be solved. You are pushing out fluid while running down the road. Then the radiator sucks it back from the overflow.
non-VTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sirguy01 &raquo;</TD></TR><TR><TD CLASS="quote">00 SiR, bensons sleeved 2.0L R</TD></TR></TABLE>
headgasket? check under your rad cap for milky stuff......i bet you are getting coolant in the oil.......
Old Aug 3, 2006 | 03:15 PM
sirguy01's Avatar
Default Re: my rad fluid is evaporating... (non-VTEC)
i knew i should have replaced the rad cap... still oem... should i be looking for a 1.3 and higher?
ck123
Jul 21, 2006 08:33 PM
DFW
14
Apr 17, 2006 09:51 PM
djay86
Jul 27, 2005 04:05 PM
jeffb16
May 31, 2004 08:43 AM
BoostedGSRBubble
May 26, 2002 02:39 PM
