My quest for boost.
Old Feb 28, 2009 | 08:51 PM
patmann911's Avatar
Icon2 My quest for boost.
alright i have a 1998 ex coupe that ive had stock with i/h/e. Well i got a hella deal on a b16a2 and im looking to build it for boost. This is my daily driver street car. So im looking for something thats reliable. I want to get somewhere in the 250-300 hp range. So what are some good turbos pistons rods cams etc for a reliable set-up. Im looking to build it all the right way. Any information on boost helps. Thanks in advance.
Pat
Old Feb 28, 2009 | 09:11 PM
bigD's Avatar
Default Re: My quest for boost.
well start in the faq at the top of the page there is also a thread all about b16's with good info. You also dont need to build it for 300hp I have been doing it for 3 years now, use quality parts and get a good tune you will be fine.
Old Feb 28, 2009 | 10:17 PM
jdm602's Avatar
shitttt you dont need to build it untill after about 400 wheel. then you might wanna look into pistons and rods if you want more power.
i made 351 wheel on the stock b16a2 only on 12 lbs. and that was low boost.
Old Feb 28, 2009 | 11:04 PM
patmann911's Avatar
well heres the situation. I got a b16a2 today. i got it for a good price but its in pieces. theres one spot of scoring on the crank and all the rods have really mild scoring on them. so i didnt know if i should just replace them with honda parts or if i should go all out with aftermarket pistons for lower compression. Im gonna take the crank to a local shop and see if it needs to be machined or what not. other than that everything on the motor is in good shape.
Old Feb 28, 2009 | 11:11 PM
jdm602's Avatar
well since you have the block and crank with no pistons or rods i would get some eagle rods and forged pistons. (cp caugh caugh). but i have my own opinion on pistons that others dont like usually haha. i would go at least 10:1 if your going to turbo it. i wanna try 11:1.
Keenor
Jan 18, 2011 06:56 PM
bosstedb18b
Feb 27, 2010 04:23 AM
SLPN H
Mar 2, 2009 07:47 AM
Del$olB16A3
Mar 27, 2005 07:23 AM
Mr. JDM-GSR
Dec 2, 2003 01:41 PM
