my exhaust is making a weird noise on shifts. check it out
heres my setup.
97 civic coupe
d1678
greddy TD40H-19T Cast Manifold, Emanage, 310cc Injectors, and a presicison fmic
its hard to explain the noise it make because i cant type the noise, that would be gay, but in between shifts it kinda sounds like when u come to a stop lite and throw it in 1st and let go of the gas. and a small flmae comes out of my exhaust to is this bad?
97 civic coupe
d1678
Re: my exhaust is making a weird noise on shifts. check it out (nastyeghatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nastyeghatch »</TD></TR><TR><TD CLASS="quote"> and a small flmae comes out of my exhaust to is this bad?</TD></TR></TABLE>
Well do all the other cars you see on the road throw flames? If not then you can assume thats not good.
Who is Mr Robot?
Re: my exhaust is making a weird noise on shifts. check it out (nsxmatt)
you have no cat right? it just running rich on decel, kind of makes a popping noise... if you have not fat then flames are normal if you are running rich
OG triple OG
no i think sohc's are gay.....
but if you have too much fuel in the right columb , when you let off , excess fuel will burn in the exhaust.
