My Dyno. :)
Old Aug 9, 2004 | 05:51 PM
HXMan's Avatar
Default My Dyno. :)
Weekend before last finally made the trip to Whip Factory and got my car tuned by the owner Dave. Excellent experience. Dave is a great guy...I will recommend him to anybody. I am very happy with the power we made. The car is so much more fun to drive now...except for the fact 1st gear just goes up in smoke, and 2nd does for the most part too.
274whp 204wTQ at 10psi
Ecutout NOT open..ran out of time so we didn't tune with it open, just closed. We spent about 2 hours on the dyno.
Before tuning at 7psi when I brought the car in, after tuning at 10.
Pics of my setup and what I have can be seen in this thread.
https://honda-tech.com/zerothread?id=905907
Pics of the car can be found here.
https://honda-tech.com/zerothread?id=938679
I'd like to thank my friend Adam for being around to help and for moral support, Dave for his awesome tuning, Steve for all my welding and fabrication needs, my Dad for his fabbing, Ben at importparts.com for alot of the stuff I needed, Kyle at wiredspeed.com for more parts I needed, Joel and JT at Extreme Parts, and everyone else on HT for all their knowledge!
The car is in no way done. I'm planning to keep running it at this level untill it breaks, and/or I save enough for rods and pistons. Hopefully a Small CF wing, seats, tranny rebuild, and more will also be in store for the car as well.
Thanks for looking!
Levi
Modified by HXMan at 7:16 AM 8/10/2004
Old Aug 9, 2004 | 06:34 PM
DENCIO's Avatar
Default Re: My Dyno. :) (HXMan)
nice #s and nice set up too
Old Aug 9, 2004 | 06:42 PM
Charles B.'s Avatar
Default Re: My Dyno. :) (hookonboost)
nice numbers, i love your setup
Old Aug 9, 2004 | 06:49 PM
B18bEK's Avatar
not bad ...nice setup tho.
Old Aug 9, 2004 | 07:38 PM
Ri5e's Avatar
Default Re: (B18bEK)
Wow, 274 WHP @ 10 psi, not bad. Type-R motor, I would expect higher #'s.
Old Aug 9, 2004 | 08:04 PM
FredoSP's Avatar
Default Re: (BG Boost)
I think the numbers are good
Old Aug 9, 2004 | 08:19 PM
dornon13's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BG Boost &raquo;</TD></TR><TR><TD CLASS="quote">Wow, 274 WHP @ 10 psi, not bad. Type-R motor, I would expect higher #'s. </TD></TR></TABLE>
thought it was a gsr?
japrex's Avatar
nice setup and numbers...so where is this whipfactory? im from the midwest and was just wondering.
Old Aug 9, 2004 | 08:34 PM
dunkd's Avatar
this is the car with all the pretty pipes
Old Aug 9, 2004 | 08:49 PM
Rod.'s Avatar
Default Re: (dunkd)
good #'s....i like your car
Old Aug 9, 2004 | 09:03 PM
SOHC_MShue's Avatar
your setup is beautiful
Old Aug 9, 2004 | 09:18 PM
MiKeAhOwSkI's Avatar
Default Re: (redturbocivic)
awesome numbers man! can't wait to see that beast !
Old Aug 9, 2004 | 10:06 PM
B18bEK's Avatar
Default Re: (dornon13)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dornon13 &raquo;</TD></TR><TR><TD CLASS="quote">
thought it was a gsr?</TD></TR></TABLE>
even so ... i've seen stock LS make over 290hp @9psi. most gsr yeild 300hp + @10psi. maybe the exhaust was restrictive since he mentioned the cutout ... but who knows.
Old Aug 9, 2004 | 10:24 PM
slowsi00's Avatar
pimp ****.
dave said ur car was fly'n.
Old Aug 9, 2004 | 11:22 PM
SiBirdie's Avatar
Default Re: (slowsi00)
I have a really good feeling, that if you dyno it with the Cutout open. You'll probably hit 300whp. Do a baseline with A/F with the Cutout open for me yah ? I really curious will you run rich and the power gain with it open. But that some nice # bro.
Old Aug 9, 2004 | 11:27 PM
Suprdave's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18bEK &raquo;</TD></TR><TR><TD CLASS="quote">
even so ... i've seen stock LS make over 290hp @9psi. most gsr yeild 300hp + @10psi. maybe the exhaust was restrictive since he mentioned the cutout ... but who knows.</TD></TR></TABLE>
Conservative Tune-up....He said he couldn't afford to rebuild it till next year.
Exhaust was restrictive tho, I didn't want to run the cut-out ona car tuned with the Exhaust on...Will run more boost (less back pressure) and leaner tuneup. That's a good way to blow up a motor.
PS: I've never seen an LS make 290whp on 9psi with a 57 trim, anything is possible tho.
Old Aug 9, 2004 | 11:30 PM
Smokinsax's Avatar
The Boot
great setup...
why do you have 2 links listed going to the same thread?
That piping is sick BTW!
Old Aug 10, 2004 | 04:06 AM
RacerXI's Avatar
Default Re: My Dyno. :) (SOHC_MShue)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue &raquo;</TD></TR><TR><TD CLASS="quote">your setup is beautiful </TD></TR></TABLE>
Nice work
menkio's Avatar
Default Re: (Smokinsax)
sohc
Old Aug 10, 2004 | 04:17 AM
HXMan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Smokinsax &raquo;</TD></TR><TR><TD CLASS="quote">great setup...
That piping is sick BTW!</TD></TR></TABLE>
Whoops...fixed that link.
Old Aug 10, 2004 | 06:24 AM
G
sh!t happens.
Default Re: (HXMan)
nice numbers man..
Old Aug 10, 2004 | 08:13 AM
B18bEK's Avatar
Default Re: (Suprdave)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suprdave &raquo;</TD></TR><TR><TD CLASS="quote">
my stock LS hit 290hp @9psi with a very conservative tune. when we made it a little more aggressive i hit 315hp @9.5psi. so it is possible. still good numbers and i'm sure it still has more potential
Old Aug 10, 2004 | 08:33 AM
TurboJesse
Guest
Posts: n/a
my stock LS hit 290hp @9psi with a very conservative tune. when we made it a little more aggressive i hit 315hp @9.5psi. so it is possible. still good numbers and i'm sure it still has more potential </TD></TR></TABLE>
with a 57 trim?
Turbo E's Avatar
i see a GSR motor int the pics.???
Old Aug 10, 2004 | 09:07 AM
Boltz's Avatar
Default Re: (Turbo E 604)
Hell yea! Looks fun
