Is my drain ok? (I NEED HELP!)
Old Jun 18, 2004 | 02:11 PM
tolowhb's Avatar
Default Is my drain ok? (I NEED HELP!)
Hello, heres my problem. I have an oil drain kit from fast-turbo and I am using it along with my greddy kit. Well anyways there is a flange that attaches to the turbo it's self, then a fitting goes inside the flange (the fitting attaches to the drain line) Well I think it leaks from where that fitting goes into the flange ( I never used and telfon tape or sealant on those threads but it goes in very tightly) It doesnt leak much but I get worried that my seals in my turbo are being ruined . I mean it boosts fine, I dont lose any oil besides my tiny leak, and it also holds steady boost. But I dont know if my drain is ok, please help me!!!! Also what are the signs of blowing seals in the compressor?
Pic of drain from the top
Another one
Pic of drain from the side
Pic of leak from underneath
Old Jun 18, 2004 | 02:33 PM
DaX's Avatar
DaX
Loved
Community Favorite
you should use teflon tape.
Old Jun 18, 2004 | 02:40 PM
boostedcivichatchbacksi's Avatar
Default Re: (DaX)
ehhh i dont like it....
Old Jun 18, 2004 | 02:44 PM
tolowhb's Avatar
Default Re: Is my drain ok? (tolowhb)
Any suggestions?
Old Jun 18, 2004 | 03:00 PM
Boofster's Avatar
teflon
Old Jun 18, 2004 | 03:03 PM
tolowhb's Avatar
Default Re: Is my drain ok? (Boofster)
Yeah I am going to do the teflon tape thing tomorrow for sure. I have been told the drain line angle looks fine from stan from fast turbo.
Old Jun 18, 2004 | 03:47 PM
FredoSP's Avatar
ddddaaammm use an open ended wrench, I see you totally killed the return AN fitting with vice grips
Old Jun 18, 2004 | 04:00 PM
AspectIndustries's Avatar
Default Re: (DaX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaX &raquo;</TD></TR><TR><TD CLASS="quote">you should use teflon tape.</TD></TR></TABLE>
Use teflon tape where? Thanks.
Old Jun 18, 2004 | 05:49 PM
tolowhb's Avatar
Default Re: (synik)
BUmp
Old Jun 18, 2004 | 06:48 PM
Dr Pooface's Avatar
Default Re: (tolowhb)
Modified by Dr Pooface at 8:37 AM 6/19/2004
Old Jun 18, 2004 | 07:35 PM
J337_UNIT's Avatar
Default Re: (Dr Pooface)
your drain looks ok
Old Jun 18, 2004 | 07:55 PM
Jared's Avatar
Default Re: (J337_UNIT)
hey buddy you dont use teflon tape on an fittings, they use a flare to seal.
Old Jun 18, 2004 | 07:59 PM
Muckman's Avatar
Moderator in Chief
Default Re: (Jared)
Thats what I thought too. Stan used to have an install section on Fast-turbo.com and I remember he specifically said do NOT use teflon on AN fittings. They seal on the flare. If it leaks tighten it more.
Old Jun 19, 2004 | 07:37 AM
Dr Pooface's Avatar
Default Re: (Muckman)
Edit: images deleted. Don't know what I was thinking.
Old Jun 19, 2004 | 08:36 AM
m R g S r's Avatar
Yea, the nipple is what seals on the AN fittings. Did you assemble those lines and fittings yourself?
I had a drain that looked similar to that, just at little less of an angle, and I think I blew the turbo seals after like 4k miles. I am not positive that they were blown, but I had some oil sots near the inlet of the compressor.
Old Jun 19, 2004 | 09:30 AM
spoolinlude's Avatar
I live under a rock
Default Re: (m R g S r)
don't use teflon tape unless you want to blow-up the turbo..... use teflon paste if anything....
Old Jun 19, 2004 | 09:52 AM
DaX's Avatar
DaX
Loved
Community Favorite
I said use teflon tape on where the NPT threads into the oil return flange. Do not use teflon tape on the AN fittings.
Old Jun 19, 2004 | 09:54 AM
dan240t's Avatar
Default Re: (spoolinlude)
i believe its still on stan's site...
you can use teflon tape on the 45* angled adapter because the one side is NPT IIRC. the AN side you obviously dont use it though.
do you have a good gasket between the outlet flange and the CHRA?
edit - pic.
Old Jun 19, 2004 | 10:35 AM
vtec69's Avatar
Default Re: (USDM dan)
I could be completely wrong but it might be leaking from the top where the oil feed comes into and just dripping down.
That might be one thing to check.
But your return looks good to me looks like it should flow just fine without a problem
-Brian
alex1320
May 13, 2013 12:34 PM
blwn95civic
Feb 4, 2008 12:29 AM
avotegra
Apr 6, 2007 02:42 PM
TAG
Dec 15, 2003 09:46 AM
BlueShadow
Jan 23, 2003 05:58 AM
