My buddy boosting his rhd integra
My buddy is boosting is teg and was asking me what parts he needed to do so. I just wanna make sure i told him all the right parts. If there is anything missing please let me i know. Where trying to make roughly anywhere from 250-350 whp. Possibly how many pounds should i be boosting. I already seen the thread on here that was for ls turbo 900 pages long :-s
Stock b18b roughly 10000 on engine stock internals
Advised to buy
garrett turbo kit t3t4
T3/T4 GARRETT T04E
Godspeed Intercooler kit (with intercooler, pipe, silicone, clamp)
B16 B18 Cast Iron Turbo Manifold
Stainless Steel Down pipe (2.5" or 3.00)
Stainless Steel Dump Pipe set
Blow Off Valve (type-rs)
Godspeed 38mm wastegate (7psi spring )
Steel Braided oil feed line, with rubber oil return line (complete kit)
.60 Compressor A/R
.63 Turbine A/R
3.0" Inlet / 2.0" Outlet
Oil Cooled Shaft & Internals
Hondata s300
Fuel rail/ 400cc injectors
Walbro 255 fuel pump
skunk2 intake mani and throttle body 68mm
Advised to buy
T3/T4 GARRETT T04E
.60 Compressor A/R
.63 Turbine A/R
Hondata s300
Re: My buddy boosting his rhd integra
i would say around 10-12 psi would be in your power goals, would he be interested in a boost controller or gauges?
Do we need both a boost controller and gauges. Cause i know some boost controllers come with gauges on it. If we get the car dynoed will be just need the gauges??
get a 3 bar map sensor and a good boost controller and run aroun 14-18lbs of boost to get around 300whp. when I tuned my car I ddin't care about lbs of boost I just told my tuner I wanted 300whp.
