My B18C1 Engine Build/Assembly
No-Traction = Fun
Have a good friend that was talking about his 12sec Mercedes E55 AMG, I was like oh really lets go for a right in a 1.8L 4cyl I have, long story short he would not stop talking about my car for the rest of the night. He could not belive it....lol
Even I admit, I'm interested in some in-car video on the street or course again. No more dyno videos. Let's see this thing rock. I'm so proud *sniffle* *sniffle*.
Was just thinking. At what RPM range do you feel that full pressure of 19psi is being felt now with the new intercooler? (Are you retuning yet, as I know you're about 5-8% leaner now than with the older I/C.) I'm just noting this kind of feedback in my records.
Would you say that using a larger intercooler allows the Turbo to operate at a higher efficiency then using the smaller intercooler?
So in other words say "X" Turbo becomes inefficent at 20psi. Would upgrading to a larger intercooler raise the efficiency level to say 23 psi (just an example) Since the intercooler should do a better job off cooling the intake charge when it reaches the ineffecent boost levels?
Just curious what youre insight is?
5-8% leaner from just a intercooler upgrade seems as though it has a significantly better cooling effect
Yeah same here man, Washington has got some lurkers! I still have a habit of blocking my plates when I take pictures for my build. So you can't be too careful, hell i'm actually debating updating my build with what I plans to do but who knows, I like the input and feedback i guess! Hahaha
congrats on the build
The problem is if you go TOO big or too thick, the pressure drop that the intercooler acts on the entire system will cause the turbocharger to not be as responsive, and it takes another 2 psi to get the same power as you had before. In this case, Calidad is fine as this one isn't too thick.
That's exactly the point, hence my animated drawing. Remember, an intercooler is nothing but a large heat exchanger. Ingested air from the turbocharger becomes heated as it compresses and goes down into the the turbo outlet to the intercooler. If the intercooler is a more efficient design. (sometimes, larger is enough for it to be that way), it will have a better ability to cool that charge pressurized air as it goes through the louvered fins. This then "exchanges" the hotter air into colder air, so that it is much cooler as it enters into the combustion chamber. the fact that it is more dense air makes the car a little lean (not too much) but should still be retuned ever so slightly to make sure its not too much.
No-Traction = Fun
seems like it comes on at about 4500 RPM
No-Traction = Fun
If you could. Give me a bit more breakdown of the rpm range for the amount of pressure that's being run. Since you're running on AEM, I'm sure you can have Bisi, (or yourself, depending upon your proficiency with the software) as to an rpm/boost pressure extrapolated curve that can be saved on an Excel file. I've had done before, but I'd like to get more feedback data on what you're experiencing, as well as your impressions as you drive the car with the larger intercooler.
Please also PM the file if you happen to create one.
No-Traction = Fun
Are you referring to my boost per gear chart?
No-Traction = Fun
