My B18C1 Engine Build/Assembly
Old 01-02-2013, 09:14 AM
  #3176
Natural Aspirations's Avatar
Default Re: My B18C1 Engine Build/Assembly
This is the arrangement you want the gears when the crank is aligned. This shows both cams retarded a few deg
Old 01-02-2013, 09:19 AM
  #3177
No-Traction = Fun
CaliforniaDad's Avatar
oh really?
Old 01-02-2013, 09:20 AM
  #3178
No-Traction = Fun
okay let me take a picture before I move anything
Old 01-02-2013, 09:28 AM
  #3179
hondad6's Avatar
In that pic ^^ you should be able to set the dials to zero, then just line the cam gears up without moving the cams (harder than it sounds I know). If you are at TDC and zero across the board you should be good to go. I have never dealt with adjustable cam gears so I am sure I am over simplifying. I also know you dont want another motor failure so I feel your hesitancy. Another question is, is bisi gonna change the cam degrees anyways while he is tuning the car?
Old 01-02-2013, 09:42 AM
  #3180
No-Traction = Fun
okay just to clarify, I started over.
Removed the Timing belt, set both cam gear settings back to (0) lined all the marks up, reinstalled the belt and checked my numbers. I have not moved anything else. So right now with the crank at true TDC the cam gears line up as so. Here are the measurements again.
ex opens .040" @ 60 deg BBDC
Ex closes .040" @ 20 deg ATDC
Max Lift @ 111.15 deg BTDC
In open .040" @ 36 deg BTDC
In closes .040" @ 50 deg ABDC
Max lift @ 97.5 deg ATDC
Old 01-02-2013, 09:43 AM
  #3181
No-Traction = Fun
suggestions??
Old 01-02-2013, 09:52 AM
  #3182
Originally Posted by Natural Aspirations
Currently:
IN 97.5
EX 111
1 cam deg = 2 crank deg (depending how the gears are marked you may need to experiment)
Advance:
Intake 5.75 deg on the gear (97.5+11.5=109)
Exhaust 2 deg on the gear (111+4=115)
Old 01-02-2013, 10:27 AM
  #3183
****, that's not right....
Intake is ATDC needs to go +
Exhaust is BBDC needs to go -
Old 01-02-2013, 10:36 AM
  #3184
rich7777's Avatar
Is that where it naturally sits ? Can you move the gears individually (slightly) with a spanner so the marks line up without them returning to that position ? (there for everything would be lined up)
I'm thinking this problem is in the cam its self at the moment.
Old 01-02-2013, 10:48 AM
  #3185
cruizinmax's Avatar
You can but be careful, advancing the intake will put the valves closer together.
Turning the intake cam 1 tooth clockwise is retarding it.
Old 01-02-2013, 10:50 AM
  #3186
No-Traction = Fun
okay here are my events after I followed your advice on gear settings
Advance:
ex opens .040" @ 64.5 deg BBDC
Ex closes .040" @ 15.75 deg ATDC
In open .040" @ 52.75 deg BTDC
In closes .040" @ 38.25 deg ABDC
Camshaft Card Specs
ex opens .040" @ 62 deg BBDC
Ex closes .040" @ 12 deg ATDC
In open .040" @ 21 deg BTDC
In closes .040" @ 59 deg ABDC
Old 01-02-2013, 10:55 AM
  #3187
Julio@Bisimoto's Avatar
Icon3 Re: My B18C1 Engine Build/Assembly
Happy New Years Californiadad! Your project is coming along very nicely and looking forward to the completion!
Factory markings are never perfect for both TDC and camshaft aliment. Then with machining of the block or cylinder head it will throw it off even further...
As long as you have the true TDC of the crankshaft and are degreeing the camshafts utilizing opening and closing numbers, it does not mater what the cam gear markings will show.
Old 01-02-2013, 11:04 AM
  #3188
No-Traction = Fun
Thanks Julio!
I was hoping to have the car completed so I can bring it in for a break-in and tune this week, but I have been fighting this timing alignment thing for the last 3 days Uggg. I have established true crankshaft TDC using a dial indicator for the number #1 piston. So what your saying is align the cam gear timing marks as close as I can, and then start dialing in my open and close events from there right?
Old 01-02-2013, 11:10 AM
  #3189
Exhaust cam is right, intake is off.
Old 01-02-2013, 11:11 AM
  #3190
2000GSRTypeR's Avatar
Can you please post up a picture with all the timing marks at TDC without the timing belt on sir? To me it seems like the cams are moving on you when you are trying to put your timing belt on. I borrowed a cam lock tool from my old job Majestic Honda to ensure that the cams do not move on me while I did my timing belt. Please excuse my ignorance as I have never degreed in cams. Therefore I do not know if you degree the cams in before or after you put the timing belt on.
Old 01-02-2013, 11:18 AM
  #3191
No-Traction = Fun
cams are not moving when I install the belt. Im using a cam locking tool.
Old 01-02-2013, 11:20 AM
  #3192
Thanks Julio!
Sounds good, when you get it dialed in give us a call for an appointment!
Correct, the markings on the cam gears are irrelevant when degreeing camshafts. Get them close, then start dialing them in.
  #3193
Your correct... I told him incorrect. First day back at work after the holiday is a bit hectic.
Old 01-02-2013, 12:58 PM
  #3194
No-Traction = Fun
okay as it stands right now my events are as follows.
Intake Gear Setting -6
Exhaust gear Setting +3
Ex opens .040" @ 64 deg BBDC
Ex closes .040" @ 16 deg ATDC
In open .040" @ 22 deg BTDC
In closes .040" @ 63 deg ABDC
Camshaft Card Specs
Ex opens .040" @ 62 deg BBDC
This appears to be as close as I can get the opening and closing events. If I make any adjustments to get me closer to either event it throws the opposing even farther from spec. Example if I get the intake open event dead on 21 deg its sends my close event to 66 deg.
Follow me?
Old 01-02-2013, 12:59 PM
  #3195
cruizinmax's Avatar
Your intake cam is 1 tooth advanced. Move it clockwise 1 tooth and move the intake cam to +3.
Old 01-02-2013, 01:05 PM
  #3196
No-Traction = Fun
are you kidding me? my intake cam is at -6 right now. If I swing it all the way to a +2 my open and closing events will be way way way off.
Old 01-02-2013, 01:10 PM
  #3197
No-Traction = Fun
If i move the intake gear 1 whole tooth clockwise that is going to make my timing marks way off. Remember when I had the head on the bench and I was checking valve to valve clearance I had the cam gear timing marks lined up. So if i do that my chart I made is useless.
Old 01-02-2013, 01:37 PM
  #3198
I have added enough confusion here.... I believe CD has the cams adjusted properly in spec now. It is very strange that the intake cam wants to be set a tooth off to be "proper". I hope to get my hands dirty this weekend.
Old 01-02-2013, 01:52 PM
  #3199
cruizinmax's Avatar
Your cam marks are still going to line up, you will just have to move the crank 1 degree more to get them there.
Old 01-02-2013, 02:15 PM
  #3200
No-Traction = Fun
I believe I got it now.
intake - 5.5
exhaust + 3
Ex closes .040" @ 15 deg ATDC
To check max lift Exhaust I measured @.050" before max was 74 deg and 156 deg @ .050" after peak so 74+156= 230 divide by 2 = 115 Deg max lift center
In open .040" @ 24 deg BTDC
In closes .040" @ 61 deg ABDC
To check max lift Intake I measured @.050" before max was 68 deg and 150 deg @ .050" after peak so 68+150= 218 divide by 2 = 109 Deg max lift center
BINGO!!!!
so final numbers are
Intake retard -5.5
Exhaust advance +3
Quick Reply: My B18C1 Engine Build/Assembly
