MSD Removal I Got Q's???
Old Jan 25, 2007 | 08:17 PM
rex_racer728's Avatar
Default MSD Removal I Got Q's???
Well I got this car. Its a 1994 Civic Hatch with a fully built D16z6. Its a F/I setup.. --Fully forged bottem end-Sleeved-JG Camshaft-Springs Retainers-JG PnP Head-STR Drag I/M-T3/T4 .60/.63 57 trim-3" DP etc..
-72lb injectors-SX fuel pump-SX FPR
-NOS Wet Nitrous system currently at a 70 shot
-Haltech Managment-MSD 6al ignition box-Blaster SS coil
The car made 418/317 at 22 psi w/ 70 shot.
Sooo my question is I read horror stories about MSD systems on this site and the car actually breaks up a little but upwards of 7400 rpms. Now i dont know if it is the tune or the MSD system but I was wonderin if I pulled the MSD out can the OEM ignition handle the power.. I would love to eliminate any extra or unneeded parts in my car that may just be screwing with it.. So for you expierenced H-T members I could really use some opinions on this subject...
Old Jan 26, 2007 | 01:22 PM
Integra21's Avatar
Default Re: MSD Removal I Got Q's??? (rex_racer728)
+1
Old Jan 26, 2007 | 02:05 PM
Dunc's Avatar
BCICAN
Default Re: MSD Removal I Got Q's??? (Integra21)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Integra21 &raquo;</TD></TR><TR><TD CLASS="quote">+1</TD></TR></TABLE>
Stop post whoring and give information.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rex_racer728 &raquo;</TD></TR><TR><TD CLASS="quote">Haltech Managment-MSD 6al ignition box-Blaster SS coil
Sooo my question is I read horror stories about MSD systems on this site and the car actually breaks up a little but upwards of 7400 rpms.</TD></TR></TABLE>
Usually people say that the 6AL system is trash. I've never had a single problem with my Digital 6+ system. Try either a better system or a different manufacturer if it comes down to that. But in the mean time try this:
1.) Pull the distributor cap off and look at the contacts on the inside. If they look like the picture below then replace the cap and that will help if not fix the problem. Notice the grossness on the metal contacts? That's something you don't want.
2.) Pull the spark plugs and make sure they are the right ones. You could try some proven NGK BKR7E plugs if you have some no name crappy ones in there.
3.) While you have the spark plugs out, check the gap. If the gap is like .035+ then you are likely just blowing out the spark. When that happens you will have the exact problem you have described. Gap them down to like ~.026-.028 and give that a try.
4.) As much as people bitch and moan about MSD's on here take it as a grain of salt. Typically they buy the cheap version and then wonder why it isn't working great. MSD's do work.
Old Jan 26, 2007 | 10:45 PM
Integra21's Avatar
Default Re: MSD Removal I Got Q's??? (Dunc)
[QUOTE=Dunc]
hey jerk, i did not have useful information to add. I too was wondering about the problem. Thanks for you informative reply. I will no replace the cap and get some heat range 8 plugs.
Old Jan 27, 2007 | 09:08 AM
Dunc's Avatar
BCICAN
In that case I apologize. How much power do you have right now? You might not need 8 heat range plugs.
Old Jan 27, 2007 | 01:44 PM
Integra21's Avatar
500whp on pump
630whp on race
Old Jan 27, 2007 | 09:32 PM
Dunc's Avatar
BCICAN
Nevermind haha, you might need them
Old Jan 28, 2007 | 02:42 PM
Integra21's Avatar
Old Jan 28, 2007 | 05:13 PM
JSPECSIR's Avatar
i have a 6al and have seen several others run them with no problems. just keep in mind if you dd this car that ss blaster is usually good for about a year. also msd has a great tech line if your having problems you should call em. i can say that msd makes hella spark compared to oem. you can hook the 6al to the oem coil and get way better sparkalso.
Old Jan 28, 2007 | 06:26 PM
Tony the Tiger's Avatar
Default Re: MSD Removal I Got Q's??? (JSPECSIR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JSPECSIR &raquo;</TD></TR><TR><TD CLASS="quote">just keep in mind if you dd this car that ss blaster is usually good for about a year. </TD></TR></TABLE>
3rd year on my blaster SS coil, daily driven, 380+ WHP.
And I think 6th year on the SS coil on my other car, JRSC D16Y8 @ 9 psi.
The SS coils generally are pretty good IMO, but I heard otherwise and NOT to touch any digital stuff from MSD (Digital-6, DIS2/DIS-4, Digital-7, etc).
Old Jan 28, 2007 | 08:56 PM
Dunc's Avatar
BCICAN
Default Re: MSD Removal I Got Q's??? (Tony the Tiger)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tony the Tiger &raquo;</TD></TR><TR><TD CLASS="quote">
The SS coils generally are pretty good IMO, but I heard otherwise and NOT to touch any digital stuff from MSD (Digital-6, DIS2/DIS-4, Digital-7, etc).</TD></TR></TABLE>
Same here, ~3years and 40,000 miles varying between 375-430whp on the Blaster SS. Well the entire MSD setup for that matter (Digital 6, Blasters, Cap, Wires).
Old Jan 29, 2007 | 03:18 AM
JSPECSIR's Avatar
thats cool^^^ ive had my setup 4 year, im on my third coil.
Old Jan 30, 2007 | 06:08 PM
Integra21's Avatar
my cap looks like the one pictured. also looks like i should replace the rotor as well cause its showing a little wear also.
does anyone know the part number from MSD for the cap and rotor? (LS B18B engine)
all i could find were VTEC parts.
and for the plugs. I used the BRK7E's on my previous turbo gsr. For the heat range 8, what is the number? BRK8E's ??? anyone have a NGK part number?
thanks - i searched and cant seem to find the correct ones.
Old Jan 30, 2007 | 08:56 PM
Dunc's Avatar
BCICAN
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Integra21 &raquo;</TD></TR><TR><TD CLASS="quote">my cap looks like the one pictured. also looks like i should replace the rotor as well cause its showing a little wear also.
thanks - i searched and cant seem to find the correct ones.</TD></TR></TABLE>
Yea, your cap is definitely causing part if not all of the issue if it looks like my old one that I pictured. I'll feel like a different car with that replaced Good luck.
1.) 94-01 Integra LS MSD Cap - Black: 8292, Red: 82921, Extreme Cap: 82922
http://www.msdignition.com/sci_8.htm
2.) The NGK plugs do not come in BKR8E. The equivilent to the BKR8E's is:
Series 8's - NGK R5671A-8, Stock# 4554
Series 9's - NGK R5671A-9, Stock# 5238
Old Feb 1, 2007 | 07:07 PM
Integra21's Avatar
thanks a lot
which cap is the best for my app? 500whp daily driven...
Since i just have the msd cap, should i buy an OEM or aftermarket rotor? (its showing some wear from the wear on the cap)
THANKS GUYS!!!!
Conernr1
12
Dec 3, 2004 01:16 AM
SpdFrk
Aug 9, 2003 08:32 AM
1.8T_EG
May 14, 2003 09:45 AM
CanadaCivicSIR
Jan 30, 2002 05:47 AM
auto-gs-king
Jan 28, 2002 12:29 AM
