MSD injectors.
Old Aug 25, 2002 | 10:01 AM
b18bturbo's Avatar
Default MSD injectors.
55lb~577.5cc injectors for 300 shipped
72lb~756cc injectors for 350 shipped
96lb~1008cc injectors for 450 shipped
also have the high impedance injectors
50lb, 42lb, 38lb, 36lb, 30lb and 24lb
prices vary on thsoe models should be under 300 bucks shipped on most.
Old Aug 25, 2002 | 10:09 AM
AlphaKennyWun's Avatar
Default Re: MSD injectors. (b18bturbo)
Damn, I would have been all over this a month ago
[Modified by SO3Burner, 2:09 PM 8/25/2002]
Old Aug 25, 2002 | 03:00 PM
b18bturbo's Avatar
Default Re: MSD injectors. (SO3Burner)
up
Old Aug 25, 2002 | 03:38 PM
paulzy's Avatar
very high quality products sold by a high quality guy.
I highly reccomend these and from Viren
Old Aug 27, 2002 | 06:45 AM
b18bturbo's Avatar
Default Re: MSD injectors. (paul_vang)
up
ekb18c's Avatar
Good prices!!! free bump for you!
Old Aug 27, 2002 | 02:49 PM
bmm89's Avatar
Default Re: MSD injectors. (ekb18c)
very high quality injectors
Old Aug 27, 2002 | 03:33 PM
WA  DA  TA's Avatar
I am using the MSDs.... they work great! This is a killer deal BTW
Old Aug 27, 2002 | 08:17 PM
bmm89's Avatar
Default Re: MSD injectors. (gsx4R1)
also idles better than rc of lesser output
Old Aug 27, 2002 | 09:18 PM
lbz34's Avatar
Default Re: MSD injectors. (bmm89)
anybody know if hondata will idle the 99 lb/hr inj???
i know it will on the 72's
thanks
Sean
Old Aug 28, 2002 | 06:25 AM
downpipe's Avatar
Default Re: MSD injectors. (lbz34)
bump, buy some! i did.
Old Aug 28, 2002 | 08:10 AM
b18bturbo's Avatar
thanks
Sean
It will idle it not a proble the 96lb injectors.
Old Aug 28, 2002 | 05:59 PM
b18c1-ek's Avatar
are side feed injectors available???
Old Aug 28, 2002 | 07:01 PM
94cxhybrid-T's Avatar
New User
can you get the equivilent of 550cc that do not require the use of a resistor pack? Thanks in advance
Mike
Old Aug 28, 2002 | 08:30 PM
lbz34's Avatar
Default Re: MSD injectors. (94cxhybrid-T)
thx viren
Old Aug 28, 2002 | 10:34 PM
TurboDANDEE's Avatar
Hey Viren, im the guy that bought a set of used Bosch injectors from u, along with my friend that bought the RPM rear suspension. I was just making sure, they are the 96lbs right...how much is that equivalent to cc's? Also, are those high or low impedence and would i need to use a resistor packs? thanx in advance.
-Dandee
[Modified by JiSATSU RaceR, 7:36 AM 8/29/2002]
Old Aug 29, 2002 | 02:52 AM
Mista Bone's Avatar
D Tranny Guru
Viren, are the 30 lb injectors plug and play in a 5g hb?
If so PM me a price.
Old Aug 29, 2002 | 05:54 AM
b18bturbo's Avatar
Mike
yes sir i can..email us.
Old Aug 29, 2002 | 05:55 AM
b18bturbo's Avatar
Default Re: MSD injectors. (b18c1-ek)
I can get some if you need it.
Old Aug 29, 2002 | 05:56 AM
b18bturbo's Avatar
Default Re: MSD injectors. (JiSATSU RaceR)
-Dandee
Depends on what ecu you are running the speed pro wont need any changes but if you running hondata or aem or something that runs factorry injectors then you would need the resitor pack.. These are 96lb which is equivalenet to 1056cc
Old Aug 29, 2002 | 08:57 PM
b18c1-ek's Avatar
any price difference for 72lb side feed injectors to fit a SR20DET? if so, what is the price?
Thanks
Old Aug 29, 2002 | 09:17 PM
Viren, im using speedpro (FAST). 1056cc seems kinda big for a street car, will these idle fine?
Old Aug 29, 2002 | 10:29 PM
paulzy's Avatar
jsut buy the 72lbs...they are good over 450hp
Old Aug 29, 2002 | 11:37 PM
The thing is that I already bought the 96lbs. Will that still idle fine or is it too big?
turbociv910
Southeast (Sales)
Mar 28, 2013 07:03 AM
slostjoe
Dec 20, 2011 08:16 AM
CivicSi95
Jun 1, 2009 09:37 AM
b18bturbo
Jun 18, 2002 02:42 AM
