MSD HVC coil question
Old Apr 24, 2007 | 04:17 PM
stinker504's Avatar
Default MSD HVC coil question
I have the MSD HVC coil and cap. The coil instructions say that it can be used with stock ignition, but "USE WITH MSD 6 SERIES IGNITIONS ONLY" is stamped on the coil. It's part number 8252 if that helps any.
Does anyone use the HVC coil on stock ignitions?
Old Apr 24, 2007 | 05:51 PM
Clutch101's Avatar
Default Re: MSD HVC coil question (stinker504)
Yes .. run it with stock here.
Old Apr 24, 2007 | 06:56 PM
boostedcivicsir's Avatar
Mr. Badwrench
msd is pretty cool to talk too. but if i read it correctly, IF you are using an ignition amplifier, then use a 6. there is an hvc coil that you need to use a 7 on if that hepls.
Old Apr 25, 2007 | 09:52 AM
stinker504's Avatar
Thanks for the input. Anyone else running it with stock ignition? I just want to see if there were any bad outcomes from doing this.
Old Apr 25, 2007 | 03:16 PM
stinker504's Avatar
Bump
Old Apr 26, 2007 | 04:16 AM
stinker504's Avatar
Last bump for info.
_oemek_
Aug 16, 2004 04:16 PM
marques4130
May 10, 2003 12:16 AM
Blown90hatcH
Jan 10, 2003 09:11 PM
SIK IN DA HED
Jan 5, 2002 09:08 PM
Ray
Dec 15, 2001 10:17 PM
