msd dis-2 install help
Old Feb 22, 2003 | 01:28 PM
itrlu77's Avatar
Default msd dis-2 install help
what up everyone, im new here and really need some help with wiring a MSD DIS 2 ignitionon my B18C5.
the wiring is as follows: http://upgradetuning.com/msd_dis2_diagram.jpg
i assume that the blk/yel on thedistributor goes to the (2) red wires on the msd ignition 12volt switched towards the distributor
the brown/orange goes to the blk/yel away from the distributor
white/blue from the distributor to the white on the msd
brown/white on the msd to the whit/blue away from the distributor
after that im lost. im missing the green, brw/grn, and if the portion above is correct???
thanks again ...luis
here is what im working on: http://upgradetuning.com/IMG_0555.JPG
Old Feb 22, 2003 | 07:03 PM
PM-Performance's Avatar
Default Re: msd dis-2 install help (itrlu77)
????? DIS is for dist less cars.
did you check to see if it would even work on your car?
Old Jul 15, 2004 | 11:03 PM
calvinPGMFI's Avatar
Default Re: msd dis-2 install help (itr206)
works with an aem emsin wasted spark config
posaccord01
Mar 24, 2007 08:40 AM
terribl3jon
Welding / Fabrication
Mar 4, 2006 06:44 AM
deftones0817
Jun 20, 2005 06:59 AM
d16rice
12
Mar 23, 2005 03:41 PM
