MSD 6BTM retarding timing with boost
Can someone tell me exactly how to set the starting psi of the boost retard, do not understand how to. From what I am seeing the **** only allows you to set the rate of retard per pound of boost, does not allow you to set the what psi you want the retard to begin .
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bradboy »</TD></TR><TR><TD CLASS="quote"> From what I am seeing the **** only allows you to set the rate of retard per pound of boost, does not allow you to set the what psi you want the retard to begin .
That is correct.
</TD></TR></TABLE>That is correct.
