Moving the Actuator on a TD05-18g
Old Jul 12, 2002 | 07:06 AM
reXem's Avatar
Default Moving the Actuator on a TD05-18g
Ok last weekend I installed my new to me TD05-18g on my CRX but the actuator was hitting the block so what I did was put some spacers in to move away from the turbo and thus it cleared the block. Now my problem is that for some reason it is either not working or it became set REALLY high. When I tested for boost I was able to build over 15psi..but I only want 6psi!!!!! So if some can help me with the proper procedure on adjusting an interal wastegate that would be great thanks!
Old Jul 12, 2002 | 08:57 AM
reXem's Avatar
Default Re: Moving the Actuator on a TD05-18g (reXem)
Ne1?
Old Jul 12, 2002 | 09:23 AM
BLKMamba's Avatar
BMW Güdentyte
25 Year Member
Is this turbo came from greddy or straight from mitsu? The Greddy should already be set to 7-8 psi.
Old Jul 12, 2002 | 09:34 AM
TurBoXBirD16's Avatar
Default Re: Moving the Actuator on a TD05-18g (DB8GSR)
i really wonder for my greddy turbo
the actuator can be adjust, i am not sure if it will increase the boost without a boost controller
Old Jul 12, 2002 | 09:37 AM
DSF's Avatar
DSF
How did you install the spacers? If you installed them so that there is more pressure on the actuator arm, of course it's going to boost higher than the wastegate is set for.
reXem's Avatar
Default Re: Moving the Actuator on a TD05-18g (xbird)
I believe it is mitsu...
Old Jul 12, 2002 | 09:47 AM
reXem's Avatar
Default Re: Moving the Actuator on a TD05-18g (DSF)
I readjusted the arm after installing the spacers but it seems that I did it wrong cuz it boosts way too much.....
Old Jul 12, 2002 | 09:57 AM
DSF's Avatar
DSF
If it has a threaded actuator arm, legnthening it should lower the boost level.
Old Jul 12, 2002 | 11:30 AM
technine's Avatar
Does the actuator arm have alot of pull on it or is there not that much tension, try slacking it out a bit by lengthening it like DSF said and check and see the max boost.
slowater427
Oct 4, 2005 02:42 PM
rjc898
May 16, 2005 09:03 AM
vangc6780
Aug 14, 2004 11:18 PM
Pikachu
Jan 31, 2004 05:24 AM
maddog20
Aug 4, 2003 03:07 AM
