motor running rich after assembling and starting
Old Apr 12, 2011 | 06:31 AM
protopro88's Avatar
Default motor running rich after assembling and starting
We'll I cracked a sleeve on my boosted Ls vtec the other day with only 2500 miles on the freshly rebuilt to stock motor. So I picked up the same bottom end (b18a) but with 70k miles on it. When I went to start it up for the first time, it started and then stalled. After starting it up a couple of times it would idle, but show 11 on my aem wideband. And the idle was very "low" and rough. What could be causing this?
Old Apr 12, 2011 | 06:46 AM
94GSRMR's Avatar
Default Re: motor running rich after assembling and starting
retune
Old Apr 12, 2011 | 07:13 AM
protopro88's Avatar
How come.I would need a new tune if the compression ratio is the same and the displacment is the same. It is the same exact motor that is on.the "tune" except the bottom end has 70k on it
Old Apr 12, 2011 | 07:35 AM
BigMike0147's Avatar
Double check timing and also valve clearance. I switched heads on my block once and forgot to redo valve clearance and had similar problems.
Old Apr 12, 2011 | 07:46 AM
LocoJoe's Avatar
Retune, no 2 engines are identical.
Old Apr 12, 2011 | 10:59 PM
W!d3b0dYr3X's Avatar
^agree. If ur other motor had 100k and the new bottom end has 70k chances are ccompression wont be the exact same so re tune it
inline4
Nov 23, 2005 10:23 PM
Used2beAb16
Apr 20, 2005 05:05 AM
village_idiot
Mar 5, 2005 09:29 PM
People_Mover
Jan 27, 2002 07:25 PM
