Which Motor Mounts for turbo??
Old Sep 9, 2006 | 06:34 PM
nebulight's Avatar
Default Which Motor Mounts for turbo??
Well, I've heard when getting motor mount inserts you only need one set of either the Energy Suspension set including: Front Lower Left Torque Mount, Front Lower Right (tranny) Torque Mount, Rear Firewall Mount.
Or the Prothane ones that include: Upper Left Mount and Upper Right Mount
Which ones do I need, or do you guys recommend replacing the OEM mounts all together for something else? I really don't want anything too harsh, since this is a daily driver, but I don't mind a little vibration. Inputs???
Old Sep 9, 2006 | 06:46 PM
cluelessmale's Avatar
Default Re: Which Motor Mounts for turbo?? (nebulight)
window weld all of them
Old Sep 9, 2006 | 07:07 PM
underpressure02's Avatar
I like my solid mounts. They are cheap to make and the motor does not move at all.
Old Sep 9, 2006 | 07:12 PM
siblues's Avatar
I have the energy suspension set installed on my em1 and they are ok.I cant complain but they are nothing to brag about.They worked ok with my drag kit but with my built motor and newetup i am gonna go hasport
Old Sep 9, 2006 | 07:48 PM
nebulight's Avatar
Default Re: Which Motor Mounts for turbo?? (siblues)
Well, this is for a street car, so I'm assuming they will be okay? But do I really need both sets?
Old Sep 9, 2006 | 08:38 PM
EK k kay's Avatar
I bought an NRG engine torque damper and it eliminated 90% of my wheel hop. My car used to hop the **** out of itself until I installed the torque damper. Now it's pretty hard to make it hop at all. I feel no extra interior vibrations compared to before. $55 well spent.
Old Sep 9, 2006 | 08:40 PM
siblues's Avatar
Default Re: Which Motor Mounts for turbo?? (EK k kay)
I would think that for a street car just the motor mounts would be ok.When i had them the car rattled like crazy?
Old Sep 9, 2006 | 09:13 PM
spooncivic1's Avatar
Default Re: Which Motor Mounts for turbo?? (cluelessmale)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cluelessmale &raquo;</TD></TR><TR><TD CLASS="quote">window weld all of them</TD></TR></TABLE>
thats what i did...you notice every rattle and squeak at idle now...but wheel hop is non-existant
Old Sep 9, 2006 | 09:32 PM
RTW DC2R's Avatar
the prothane inserts are plenty stiff for me, almost too much actually. I have both top mount inserts and the rear. For the top driver side I used the race insert.
Old Sep 10, 2006 | 12:34 AM
qfast817's Avatar
Default Re: (RTW DC2R)
i have all prothane inserts mounts with window weld. no wheel hop or squeaking
Old Sep 10, 2006 | 01:28 AM
komat's Avatar
Default Re: (qfast817)
hasport mounts and torque mounts with inserts FTW
Old Sep 10, 2006 | 07:50 AM
cuin9sec
Guest
Posts: n/a
Default Re: (komat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by komat &raquo;</TD></TR><TR><TD CLASS="quote">hasport mounts and torque mounts with inserts FTW</TD></TR></TABLE>
Old Oct 27, 2006 | 07:58 AM
nebulight's Avatar
Bump because I ordered both, but they sent me the wrong Energy Suspension kit, they sent me trailer arm bushings.... But I did get the correct Prothane ones.
Will I be okay with just the prothane inserts? Because I heard that you really only need one of the two posted above, I just don't which one I need.
Old Oct 27, 2006 | 08:04 AM
turbotime's Avatar
i run the tq mount inserts and a rear mount insert, rest of my mounts are 100% OEM.
Im gonna get a tq damper tho- i got one but it didint fit the swap it was for the stock sohc :-/
skata89
Sep 4, 2006 11:37 AM
Tim.
18
Jun 14, 2005 10:54 AM
onyx00
Sep 24, 2004 01:00 PM
SOHC_Brian
Aug 11, 2004 11:30 AM
Brewer
Mar 23, 2004 07:30 PM
